blazen244 Posted October 29, 2010 Report Share Posted October 29, 2010 Right behind the radiator there is a small line that look like it comes from the throttle body. It has a coupler on it that's rotting away is there any options with this or where can I get a replacement? Link to comment Share on other sites More sharing options...
Reximus Posted October 29, 2010 Report Share Posted October 29, 2010 Right behind the radiator there is a small line that look like it comes from the throttle body. It has a coupler on it that's rotting away is there any options with this or where can I get a replacement? did you mean that solenoid valve which is on the driver side of the radiator fan shroud? usually the rubber hose rot away from long time heat and oil. just replace that section of rubber hose, then you'll be set. some model of 850's came with foam casing for that solenoid to reduce the ticking noise while it works. if that's the one rotting away, then i wouldn't worry about it too much. it's there for noise comfort reason cheers! Link to comment Share on other sites More sharing options...
blazen244 Posted October 29, 2010 Author Report Share Posted October 29, 2010 You got it that's the one and it is rotted keeps coming off so I have it zip tied now to keep it on but it's going to break. I'll look for something to replace it with Link to comment Share on other sites More sharing options...
