Anatoli Posted October 29, 2010 Report Share Posted October 29, 2010 changed the shifter bulb, but the "W" bulb is out too. I popped the "W" cover off, but not sure how to remove the whole switch? Link to comment Share on other sites More sharing options...
Anatoli Posted October 29, 2010 Author Report Share Posted October 29, 2010 ok, i had it figured out. after i removed the center console cover I had to pry the shifter cover where "W" switch sits, and then there's enough space to remove it by moving it upwards. Thanks god, no soldering is required, as only i had to put in a new bulb into the easy socket. Link to comment Share on other sites More sharing options...
db130 Posted October 29, 2010 Report Share Posted October 29, 2010 ok, i had it figured out. after i removed the center console cover I had to pry the shifter cover where "W" switch sits, and then there's enough space to remove it by moving it upwards. Thanks god, no soldering is required, as only i had to put in a new bulb into the easy socket. LOL, the W switch has a bulb?? is it the same bulb as the shifter indicator bulb or does is it more like the sunroof/seat heater switch bulb? Link to comment Share on other sites More sharing options...
Tom. Posted October 29, 2010 Report Share Posted October 29, 2010 wait... the w button lights up? seriosuly? :lol: Link to comment Share on other sites More sharing options...
Anatoli Posted October 29, 2010 Author Report Share Posted October 29, 2010 LOL, the W switch has a bulb?? is it the same bulb as the shifter indicator bulb or does is it more like the sunroof/seat heater switch bulb? not the same as shifter indicator bulb. the bulb has a blue rubber cover, so to me it is the same as in the sc816 radio (as the dash switches do not have that blue rubber cover). i went with microlamps from Radioshack (2-lamp pack for $1.79). Link to comment Share on other sites More sharing options...
db130 Posted October 29, 2010 Report Share Posted October 29, 2010 does it have a base like this? this probably means that my T5's S/E/W button is illuminated also, can anyone else confirm? Link to comment Share on other sites More sharing options...
Anatoli Posted October 30, 2010 Author Report Share Posted October 30, 2010 does it have a base like this? this probably means that my T5's S/E/W button is illuminated also, can anyone else confirm? that was the base looks like only it was black. of course they are. these cars are 10+ years old. it's not uncommon for light bulbs to burn out. Now i realize that the lock override is supposed to be lighted up. otherwise how would you see it in the dark. I missed it when i had console apart. maybe i'll take it off one more time, as it's much simpler than with 850 one. Link to comment Share on other sites More sharing options...
