blazen244 Posted November 3, 2010 Report Share Posted November 3, 2010 Have anyone swapped out their own rear shocks? If you have what tool did you use to tighten up the shock to the adapter piece. Every time I tighten the nut, the shaft start spinning. It has a cover over the shaft so I can't hold it with pliers or anything to keep it from spinning. What have you guys used? Link to comment Share on other sites More sharing options...
Keep Calm Chive On Posted November 3, 2010 Report Share Posted November 3, 2010 there is no pressure on the shock while the car is jacked up so its spinning in place. try placing a jack under the rear link to apply some light pressure to help it from not spinning. or if you have a friend have them gently pull or push the shock GENTLY so that it applies some pressure to the bolt. i prefer the lightly jack up the rear suspension so it compresses the shock just a little so its not sitting there allowing it to rotate freely fully decompressed. There is either a hex bolt or head that you can hold but the shock mount is deep dish pizza style so its hard to get something in there while holding the head Link to comment Share on other sites More sharing options...
blazen244 Posted November 3, 2010 Author Report Share Posted November 3, 2010 I remember helping my father when I was younger changing the shocks on his Montego, and he used the box end wrench and some tool that had four different shapes in the top of it to hold the shaft from spinning while you tightened with the wrench. That was some moons ago and he don't have the tools anymore just thought some one would know were to get them from. Link to comment Share on other sites More sharing options...
bergmjs Posted November 3, 2010 Report Share Posted November 3, 2010 Is this what youre looking for? http://volvospeed.com/Mods/Bilstein_rinstall.htm Link to comment Share on other sites More sharing options...
blazen244 Posted November 5, 2010 Author Report Share Posted November 5, 2010 no not quite but, it'll work thanks didn't think of that. Link to comment Share on other sites More sharing options...
blazen244 Posted November 5, 2010 Author Report Share Posted November 5, 2010 Is this what youre looking for? http://volvospeed.com/Mods/Bilstein_rinstall.htm Do you know where I can buy that tool and the other two from? Link to comment Share on other sites More sharing options...
AverageVolvo Posted November 5, 2010 Report Share Posted November 5, 2010 Wrench and allen/torx to secure the shaft from spinning? And as suggested use a jack to put some load on the shocks. Link to comment Share on other sites More sharing options...
blazen244 Posted November 5, 2010 Author Report Share Posted November 5, 2010 One other question, I have the bilstein touring shocks on it now I have four subs three amps in the trunk would the heavy duty shocks handle the load better. I'm also doing springs this. Link to comment Share on other sites More sharing options...
SladetheSleeper Posted November 5, 2010 Report Share Posted November 5, 2010 I ended up just using a set of needle nose vice grips and a box wrench. Link to comment Share on other sites More sharing options...
bergmjs Posted November 5, 2010 Report Share Posted November 5, 2010 One other question, I have the bilstein touring shocks on it now I have four subs three amps in the trunk would the heavy duty shocks handle the load better. I'm also doing springs this. Sounds like you need stiffer springs, not shocks. Link to comment Share on other sites More sharing options...
Gilhuly Posted November 5, 2010 Report Share Posted November 5, 2010 vice grips and a cheater pipe. Done. Link to comment Share on other sites More sharing options...
blazen244 Posted November 6, 2010 Author Report Share Posted November 6, 2010 I just finished installing the rear springs and the touring shocks. The car is riding great I can't remember when it rode better. The suspension just swallows up the road. I didn't have time to do the fronts and I'm still waiting for the spring seats to come in. I've had the springs in the closet for the last five years and kicking my self for not dong it sooner. I just had the motor swapped out now the suspension, next the intercooler, then on to the turbo back exhaust. Link to comment Share on other sites More sharing options...
