Furious E Posted November 11, 2010 Report Share Posted November 11, 2010 So I'm supposed to be driving five hours to PA tomorrow and can't get my car to start, so I need to resolve this issue rather quickly. Any and all help would be appreciated. So here's the situation: 1.) Car won't crank, no clicking noises 2.) Checked ground wires a.) One of the leads from the negative terminal has corroded out of its lug at the end that attaches to what I think is the starter motor b.) Soldered on new lug to no luck 3.) Headlights, windows, flashers all work, stereo does not turn on however the ani-theft light is blinking still 4.) Headlights dim when attempting to crank engine over, so the starter must be getting power i would think What else can I try and test? I found a thread about some relays next to the fuse box (fuses are all good btw). What symptoms would those cause? What I don't get is why the stereo wont work, as the fact that there appears to be current going to the starter seems to suggest a fault there. Link to comment Share on other sites More sharing options...
weston97glt Posted November 11, 2010 Report Share Posted November 11, 2010 there are relays under the fuse box, one of which is a fuel pump relay. It is red and says 103 on it. Could possibly be it. Link to comment Share on other sites More sharing options...
Keaton85 Posted November 11, 2010 Report Share Posted November 11, 2010 Have you tried jumping it? Sounds like a dead battery. Link to comment Share on other sites More sharing options...
bum2kev Posted November 11, 2010 Report Share Posted November 11, 2010 close all the doors, lock the car then unlock it. the immobilizer is on and this is the only way to do it. Link to comment Share on other sites More sharing options...
misa Posted November 12, 2010 Report Share Posted November 12, 2010 close all the doors, lock the car then unlock it. the immobilizer is on and this is the only way to do it. Could be this...but it seems like the battery is dead because the headlights dim when he attempt to crank the engine. Link to comment Share on other sites More sharing options...
Zappo Posted November 12, 2010 Report Share Posted November 12, 2010 Could be this...but it seems like the battery is dead because the headlights dim when he attempt to crank the engine. The headlights would go out completely and not come back if the battery were dead. The starter would try to take the remaining power from the battery. I doubt it is a battery problem. The two ideas stated above are more likely the cause. Link to comment Share on other sites More sharing options...
Keaton85 Posted November 12, 2010 Report Share Posted November 12, 2010 who frigin negatived my post. I'm getting sick of the negative BS on this board when it's BASIC stuff. Link to comment Share on other sites More sharing options...
Anatoli Posted November 12, 2010 Report Share Posted November 12, 2010 how frigin negatived my post. I'm getting sick of the negative BS on this board when it's BASIC stuff. what is the point of this +/- system anyway? Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted November 12, 2010 Report Share Posted November 12, 2010 what is the point of this +/- system anyway? Its stupid, its supposed to be for your reputation, but people are idiots and use it to rep down people they dont like Link to comment Share on other sites More sharing options...
Keaton85 Posted November 12, 2010 Report Share Posted November 12, 2010 It's to piss me off! I think NEU is out for me haha :lol: Link to comment Share on other sites More sharing options...
bum2kev Posted November 12, 2010 Report Share Posted November 12, 2010 So I'm supposed to be driving five hours to PA tomorrow and can't get my car to start, so I need to resolve this issue rather quickly. Any and all help would be appreciated. So here's the situation: 1.) Car won't crank, no clicking noises 2.) Checked ground wires a.) One of the leads from the negative terminal has corroded out of its lug at the end that attaches to what I think is the starter motor b.) Soldered on new lug to no luck 3.) Headlights, windows, flashers all work, stereo does not turn on however the ani-theft light is blinking still 4.) Headlights dim when attempting to crank engine over, so the starter must be getting power i would think What else can I try and test? I found a thread about some relays next to the fuse box (fuses are all good btw). What symptoms would those cause? What I don't get is why the stereo wont work, as the fact that there appears to be current going to the starter seems to suggest a fault there. its the immobilizer guys. edit, wait. what light? the little red one? i thought you meant the blinkers are blinking. nvm, im dumb Link to comment Share on other sites More sharing options...
sunnyhours4130 Posted November 12, 2010 Report Share Posted November 12, 2010 Did this get figured out? Has OP taken a multimeter to the battery? Or tested with multimeter at the starter when cranking? Link to comment Share on other sites More sharing options...
czar Posted November 12, 2010 Report Share Posted November 12, 2010 So I'm supposed to be driving five hours to PA tomorrow and can't get my car to start, so I need to resolve this issue rather quickly. Any and all help would be appreciated. So here's the situation: 3.)......... however the ani-theft light is blinking still From Hanks.. close all the doors, lock the car then unlock it. the immobilizer is on and this is the only way to do it. I think he got his answer and is on his way back to PA p.s. is it just me or does "multi quote" not work anymore? Firefox 3.6.12 Link to comment Share on other sites More sharing options...
KlausC Posted November 12, 2010 Report Share Posted November 12, 2010 It could be the electrical portion of the ignition switch. Your headlights are supposed to turn OFF when the starter engages. And there is no lead from the negative post to the starter. Do check the positive leads from the battery for corrosion. Link to comment Share on other sites More sharing options...
Zappo Posted November 12, 2010 Report Share Posted November 12, 2010 I think he got his answer and is on his way back to PA I would assume so also given he hasn't posted again. Link to comment Share on other sites More sharing options...
