Big Will Posted November 20, 2010 Report Share Posted November 20, 2010 Sweetness! Do you guys sell just the front sway bar for an AWD V70? I'd be all over this if you do! Should be the same front sway bar for an AWD as a FWD - rear bar is the one that's different. Link to comment Share on other sites More sharing options...
sconeman Posted November 20, 2010 Report Share Posted November 20, 2010 yeah definitely going to want to pick one up for my 855 this winter when I do the swap. Link to comment Share on other sites More sharing options...
magicaljake Posted November 20, 2010 Report Share Posted November 20, 2010 right on!.. i was wondering what the 2 holes were about in my new sawys in my room.... i have the rear in now.. im waiting for my engine swap to do the front... ill be sure to put it in teh second hole... thanks :D Link to comment Share on other sites More sharing options...
Oreo931 Posted November 20, 2010 Report Share Posted November 20, 2010 I am going to PM you about one of these after my finals are over. It's about time I paired something up with my 25mm rear iPd bar. Link to comment Share on other sites More sharing options...
B Mac Posted November 20, 2010 Report Share Posted November 20, 2010 Damn it. Any way to modify the old front bar? What's with you and always beating me to what I had to say?!?! Damn you John .....so yes, any way to mod the single hole style bars? Orrrrr you should totally let us do a return exchange. Just sayin Link to comment Share on other sites More sharing options...
krn Posted November 20, 2010 Report Share Posted November 20, 2010 I recently installed a pair on my 98 (front and rear) and used the front setting. I'm very happy with the upgrade and improved handling. It's pretty easy to swap between the two holes, too. Link to comment Share on other sites More sharing options...
Oreo931 Posted November 20, 2010 Report Share Posted November 20, 2010 It's pretty easy to swap between the two holes, too. :lol: Link to comment Share on other sites More sharing options...
Bah Posted November 20, 2010 Report Share Posted November 20, 2010 It's pretty easy to swap between the two holes, too. I lol'ed :lol: Link to comment Share on other sites More sharing options...
B Mac Posted November 20, 2010 Report Share Posted November 20, 2010 It's pretty easy to swap between the two holes, too. I got slapped the last time I tried that one :lol: Link to comment Share on other sites More sharing options...
Dan A Posted November 20, 2010 Report Share Posted November 20, 2010 Lucky - I've heard people on this board state that a stiffer front sway bar promotes more understeer. True or no? Link to comment Share on other sites More sharing options...
TxS70 Posted November 20, 2010 Report Share Posted November 20, 2010 Lucky - I've heard people on this board state that a stiffer front sway bar promotes more understeer. True or no? this Link to comment Share on other sites More sharing options...
TorqueSteer Posted November 20, 2010 Report Share Posted November 20, 2010 Yes, a stiffer sway bar will cause an increase in understeer and more body roll. Thus, decreasing the the stiffness of sway-bar will cause an increase in oversteer and less body roll. A similar effect can also be achieved by lengthening or shortening the endlinks. Note that the rear swaybar setup will also a play a role in the overall feel of the car. Link to comment Share on other sites More sharing options...
macman33 Posted November 21, 2010 Report Share Posted November 21, 2010 I have the same question, can the single hole bars be modified ? Link to comment Share on other sites More sharing options...
ozzimark Posted November 21, 2010 Report Share Posted November 21, 2010 Yes, a stiffer sway bar will cause an increase in understeer and more body roll. Thus, decreasing the the stiffness of sway-bar will cause an increase in oversteer and less body roll. A similar effect can also be achieved by lengthening or shortening the endlinks. Note that the rear swaybar setup will also a play a role in the overall feel of the car. If you're talking about the front sway, that's backwards: Stiffer = less roll, potentially more understeer. Softer = more roll, potentially more oversteer. I say potentially because it's all relative :P Link to comment Share on other sites More sharing options...
HPsyndicate Posted November 21, 2010 Report Share Posted November 21, 2010 I drilled an extra hole in my front ipd bars as there's enough room to do it and lucky said it would be effectively the same. He was also clear id be violating my warranty by drilling it out I painted the ends so the likelyhood for corrosion would be reduced so I figure I'm good but if I screwed it up somehow I realize I'm on my own... Link to comment Share on other sites More sharing options...
