HtownTurboBrick Posted November 23, 2010 Report Share Posted November 23, 2010 I just have it extracted to root sd card in a folder called android So it should show like this? set cmdline "rel_path=android nand_boot=0" Yea I'm HSPL, i've run several different ROM's these last few months, and at least 10 different android builds. Link to comment Share on other sites More sharing options...
Ghost Shadow Posted November 23, 2010 Author Report Share Posted November 23, 2010 I just have it extracted to root sd card in a folder called android So it should show like this? set cmdline "rel_path=android nand_boot=0" Yea I'm HSPL, i've run several different ROM's these last few months, and at least 10 different android builds. yep, you dont need to do that, unless you are just running one build, you can do many many builds but just one android directory is fine Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted November 23, 2010 Report Share Posted November 23, 2010 Yea it's not working for me. Just sits at the HTC screen forever. Dropped the MDJ froyo sense 2.4 on my phone and works like a charm. I don't see why bluetopia isn't working since MDJ froyo sense is the actual kernel for it. Link to comment Share on other sites More sharing options...
Ghost Shadow Posted November 23, 2010 Author Report Share Posted November 23, 2010 Yea it's not working for me. Just sits at the HTC screen forever. Dropped the MDJ froyo sense 2.4 on my phone and works like a charm. I don't see why bluetopia isn't working since MDJ froyo sense is the actual kernel for it. for what carrier you on? must be tmous since you were going to try bluetopia. i have the following setup hatrains 8.4 kernel blue 1.03 2.15.50 radio hard spl'd to somethign with the hspl in the end vrom wm6 loader or chucky droid rom is ok too the hard spl is a hang point too when i did the last hd2 yesterday. also transfeer files via windows not android to the sd card blue is the way to go for battery, data, hspa+, wifi, blue tooth, call clarity, fast and stable. Link to comment Share on other sites More sharing options...
Boost3237 Posted November 23, 2010 Report Share Posted November 23, 2010 Yea it's not working for me. Just sits at the HTC screen forever. Dropped the MDJ froyo sense 2.4 on my phone and works like a charm. I don't see why bluetopia isn't working since MDJ froyo sense is the actual kernel for it. is this where you got bluetopia? http://forum.xda-developers.com/showthread.php?t=843221 Link to comment Share on other sites More sharing options...
Boost3237 Posted November 23, 2010 Report Share Posted November 23, 2010 for what carrier you on? must be tmous since you were going to try bluetopia. i have the following setup hatrains 8.4 kernel blue 1.03 2.15.50 radio hard spl'd to somethign with the hspl in the end vrom wm6 loader or chucky droid rom is ok too the hard spl is a hang point too when i did the last hd2 yesterday. also transfeer files via windows not android to the sd card blue is the way to go for battery, data, hspa+, wifi, blue tooth, call clarity, fast and stable. Yea one thing I found was that sometimes the HD2 doesn't like to be unlocked or flashed if its not connected to windows. Even sometimes it goes as far as having to use HTC sync to move the files. I don't know why but it happens. Link to comment Share on other sites More sharing options...
Ghost Shadow Posted November 23, 2010 Author Report Share Posted November 23, 2010 EDIT: that link to the tmous thread is a good how to. i would follow that to get it to work. but below is what i did to get android to runs flawlessly on my phone! i use this http://forum.xda-dev...ad.php?t=820696 then copy and paste this in the android directory i am using v8.4 http://forum.xda-dev...hlight=hastarin then make sure i have this line edited in my startup.txt pointing to the right android directory set cmdline "rel_path=whereeverANDROIDis nand_boot=0" also as a pre-reequisite i have radio 2.15.50.xx i hard SPL'd my phone with HSPL3_PKG.exe flashed chucky droid rom as the windows mobile loader. if you just run clrad and then haret from the file explorer it very possible for it to hang. also on a fresh install it will create data.img (takes 10-15 minutes) edit: also let me remind you to reboot a few times to let the hd2 settle in. dont ask why i dont know but its fine after 2 or 3 reboots lol. Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted November 23, 2010 Report Share Posted November 23, 2010 is this where you got bluetopia? http://forum.xda-developers.com/showthread.php?t=843221 That's what I've been needing to see. I've just been dropping this http://forum.xda-developers.com/showthread.php?t=820696 on my phone and nothing happens. Totally unaware of task 29, autoflash and supersport. Been running MDJ Froyo Sense since yesterday and it's pretty nice, but I noticed battery life getting sucked hard. So I'll try and see if I can't get bluetopia on. Link to comment Share on other sites More sharing options...
Ghost Shadow Posted November 23, 2010 Author Report Share Posted November 23, 2010 That's what I've been needing to see. I've just been dropping this http://forum.xda-dev...ad.php?t=820696 on my phone and nothing happens. Totally unaware of task 29, autoflash and supersport. Been running MDJ Froyo Sense since yesterday and it's pretty nice, but I noticed battery life getting sucked hard. So I'll try and see if I can't get bluetopia on. you need to edit the startup.txt file though. that maybe why it doesnt work Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted November 23, 2010 Report Share Posted November 23, 2010 Did what the thread said, and works awesome. I just don't like how it automatically boots into android, barely gives me time to opt out. I need to be able to use Winmo for my IGO8 software. I'll go back and see if I can't go ahead and drop in a different rom now that I have bluetopia running. Link to comment Share on other sites More sharing options...
Boost3237 Posted November 24, 2010 Report Share Posted November 24, 2010 Did what the thread said, and works awesome. I just don't like how it automatically boots into android, barely gives me time to opt out. I need to be able to use Winmo for my IGO8 software. I'll go back and see if I can't go ahead and drop in a different rom now that I have bluetopia running. You can change the "boot to android" time its in the startup file and you adjust the number of seconds passes after it boots into windows before it autoruns android. Good to know that thread helped you, I'm glad its working. Link to comment Share on other sites More sharing options...
yangotang Posted November 24, 2010 Report Share Posted November 24, 2010 what are you using for android-based stand alone navigation software? Link to comment Share on other sites More sharing options...
Ghost Shadow Posted November 24, 2010 Author Report Share Posted November 24, 2010 what are you using for android-based stand alone navigation software? Motonav for Android uses same maps as iGO8 thus great for Win MO and Droid dual booters!! Link to comment Share on other sites More sharing options...
Boost3237 Posted November 24, 2010 Report Share Posted November 24, 2010 what are you using for android-based stand alone navigation software? I use google maps. Hasn't failed me yet. Link to comment Share on other sites More sharing options...
Serge Posted November 24, 2010 Report Share Posted November 24, 2010 I use google maps. Hasn't failed me yet. Google Maps Navigation is amazing, but I also have standalone GPS installed on the phone just in case there is no data in the middle of no where and I'm lost (and my car's navi isn't working for some reason). Always nice to have a failover. Link to comment Share on other sites More sharing options...
