bender005 Posted November 23, 2010 Report Share Posted November 23, 2010 saturday i was going to replace my timing belt on my 93 850 gtl, and got everything torn apart and put the new one on, and found that the new one was 6 ribs shorter, so i put the old one back on. test drove the car and went to take off and had no power, put the pedal to the floor and it took a long time to get going. checked the timing and its fine. drove in to work on monday and had the same problems when i first took off and it got better as i got closer to work. by the time i arrived at work the problem was gone. at lunch i went to leave work and the car started and i went to give it gas and it died. now it wont start. it cranks over, the fuel pump is pushing 45 psi and it has spark, the battery has 12 volts, checked the fuses there fine, tried the imobilizer by unlocking and locking the doors. i am stumped on this and dont want to guess and throw parts at it. thanks, B.Martin Link to comment Share on other sites More sharing options...
Gilhuly Posted November 24, 2010 Report Share Posted November 24, 2010 Either the timing isn't OK or you have a pretty big vacuum leak. Check your intake hose on the throttle body? Link to comment Share on other sites More sharing options...
bender005 Posted November 24, 2010 Author Report Share Posted November 24, 2010 Either the timing isn't OK or you have a pretty big vacuum leak. Check your intake hose on the throttle body? the intake hose and the elbow on the throttle body are brand new, had the car towed to a shop. awaiting update from them. Link to comment Share on other sites More sharing options...
