Specter86 Posted November 27, 2010 Report Share Posted November 27, 2010 I've got some fogs out of a junkyard I was wondering whatelse I need to make them work? I got the switch and the lamps I heard I need a headlight relay? Thanks in advance Link to comment Share on other sites More sharing options...
beewerks Posted November 27, 2010 Report Share Posted November 27, 2010 Apart from the foglights and dash switch, you'll need the Light Control Relay that is located under the fuse panel under the hood. The panel is held on by 4 torx screws and the relay you want is generally gray with a yellow plug in color. The one you're replacing should be green with a yellow plug. Then under the driverside dash there is another relay panel, here you will need to add a relay marked "213" on the top of it, and LCR Jumper on the side, it's white with a green plug. You will also need to plug in a black "J" relay into the same panel under the dash. Depending on the car you will need one or two. My '98 V70 already had one installed. There aren't too many vacant plugs in the panel so it's pretty easy to find the right spot for each relay. I hope this helps out a bit! Good luck and tell us how it goes. Added pics for reference: Link to comment Share on other sites More sharing options...
ohsleeper Posted November 27, 2010 Report Share Posted November 27, 2010 you will need one of these for sure. ps thanks for giving me something to do for 10 mins pps. damn its too small...let me try that again... Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted November 27, 2010 Report Share Posted November 27, 2010 ^^^^ i think its more disturbing that it took you 10 minutes to make that :arob: Link to comment Share on other sites More sharing options...
ohsleeper Posted November 27, 2010 Report Share Posted November 27, 2010 lol... that might be a bit of an exaggeration. it didnt look so bad not zoomed in haha Link to comment Share on other sites More sharing options...
Gage Posted November 27, 2010 Report Share Posted November 27, 2010 Apart from the foglights and dash switch, you'll need the Light Control Relay that is located under the fuse panel under the hood. The panel is held on by 4 torx screws and the relay you want is generally gray with a yellow plug in color. The one you're replacing should be green with a yellow plug. Then under the driverside dash there is another relay panel, here you will need to add a relay marked "213" on the top of it, and LCR Jumper on the side, it's white with a green plug. You will also need to plug in a black "J" relay into the same panel under the dash. Depending on the car you will need one or two. My '98 V70 already had one installed. There aren't too many vacant plugs in the panel so it's pretty easy to find the right spot for each relay. I hope this helps out a bit! Good luck and tell us how it goes. Now here is the thing with my 99 S70 there is no spot for the 213 relay to go into ??? I hooked up the switch and lights and they still dont work so what would i need to get mie to to work ? Link to comment Share on other sites More sharing options...
adamjjohn203 Posted November 27, 2010 Report Share Posted November 27, 2010 Now here is the thing with my 99 S70 there is no spot for the 213 relay to go into ??? I hooked up the switch and lights and they still dont work so what would i need to get mie to to work ? 99+ still need the J relay under the dash and the yellow and gray light control relay swapped in under the engine cowl fuse box. Here is a PDF of the original instructions... http://volvospeed.com/vs_forum/index.php?app=core&module=attach§ion=attach&attach_id=5305 Link to comment Share on other sites More sharing options...
jadnhm Posted November 27, 2010 Report Share Posted November 27, 2010 is the "J" relay just a normal automotive relay? Do you have to get /the/ J relay or will any regular automotive relay work? Link to comment Share on other sites More sharing options...
Specter86 Posted November 27, 2010 Author Report Share Posted November 27, 2010 Thanks so much I got my fogs up and running with just the 104 108 and a J relay thanks for all the help folks Link to comment Share on other sites More sharing options...
crazykn Posted November 28, 2010 Report Share Posted November 28, 2010 Just as a reference, the J-Relay is pretty much a standard automotive relay. Note the the 87 Pin is duplicated in the center, its not a 87a and 87b type (which means if the relay is off that the 87a will have power and the 87b pin won't). Link to comment Share on other sites More sharing options...
jadnhm Posted November 28, 2010 Report Share Posted November 28, 2010 Just as a reference, the J-Relay is pretty much a standard automotive relay. Note the the 87 Pin is duplicated in the center, its not a 87a and 87b type (which means if the relay is off that the 87a will have power and the 87b pin won't). Thanks for this. I was hoping this would be true. Link to comment Share on other sites More sharing options...
Gage Posted November 28, 2010 Report Share Posted November 28, 2010 99+ still need the J relay under the dash and the yellow and gray light control relay swapped in under the engine cowl fuse box. Here is a PDF of the original instructions... http://volvospeed.com/vs_forum/index.php?app=core&module=attach§ion=attach&attach_id=5305 cool ill give it a try Thanks Link to comment Share on other sites More sharing options...
jadnhm Posted November 29, 2010 Report Share Posted November 29, 2010 Just as a reference, the J-Relay is pretty much a standard automotive relay. Note the the 87 Pin is duplicated in the center, its not a 87a and 87b type (which means if the relay is off that the 87a will have power and the 87b pin won't). Just to clarify crazykn, how does one go about using a regular automotive relay in this application? I'm a bit confused by your explanation as it seems most descriptions of relays don't normally include bot an 87a and 87b pin. here's a good example: http://www.the12volt.com/relays/relays.asp Is this relay a SPST, SPDT, DPST or DPDT? Link to comment Share on other sites More sharing options...
jadnhm Posted November 29, 2010 Report Share Posted November 29, 2010 Maybe this helps? There is a picture on this site of the other side of the relay: http://allegro.pl/przekaznik-bezpiecznik-4ra-003510-73-volvo-s70-v70-i1297736946.html It looks to me like it says: 30 = commmon (expected) 85-86 = coil (expected) 87-87 = output, N/O, duplicated as crazykn said So both 87* pins should have the same output? I am not sure if you can buy a normal relay that does this, but you could easily duplicate it by jumpering them together either inside the relay or by connecting the relay to the plug via a little pigtail that does the jumpering. Any other thoughts? Link to comment Share on other sites More sharing options...
Gage Posted November 29, 2010 Report Share Posted November 29, 2010 99+ still need the J relay under the dash and the yellow and gray light control relay swapped in under the engine cowl fuse box. Here is a PDF of the original instructions... http://volvospeed.com/vs_forum/index.php?app=core&module=attach§ion=attach&attach_id=5305 Well i have the yellow/grey relay in there now but there still is no spot for a J relay #201 so idk wtf to think ill try and snap a pic of the fuse block under the dash when the wife gets home from work today Any other thoughts? Or you could just ask and im sure one of us on here, like myself could just send you one in the mail for like what 5.00 ;) Link to comment Share on other sites More sharing options...
