Brad850 Posted December 5, 2010 Report Share Posted December 5, 2010 Hey guys I wasn't sure where to put this question I figured this was the best place. I just recently bought a reverse el-glo panel. The dimmer switch it came with is ugly and I'd like to be able to still use my stock dimmer. The only thing is the el-glo panel has its own lighting, and then there are the 4 LEDs behind my actual cluster which are hooked up to the stock dimmer. How easy would it be to hook everything up to my stock dimmer? Do you guys know of any places online or offline I could find wiring diagrams to make the job a little easier? Or have any of you done this? Or is it even possible lol. Thanks. Link to comment Share on other sites More sharing options...
Guest kgo not real name Posted December 5, 2010 Report Share Posted December 5, 2010 nice job on that it must be hard.i want pizza lol Link to comment Share on other sites More sharing options...
Serge Posted December 5, 2010 Report Share Posted December 5, 2010 If the EL inverter accepts an input (most likely PWM), then you can use one of the interior light feeds to control that. You have to see how the dimmer on the EL inverter works (see what the voltage range is, how many pins, etc). Link to comment Share on other sites More sharing options...
InitialDriveGTR Posted December 8, 2010 Report Share Posted December 8, 2010 pink wire coming out of the dimmer controls brightness level. Link to comment Share on other sites More sharing options...
