jl2 Posted December 8, 2010 Report Share Posted December 8, 2010 The left headlamp lens of my 03 S80 is cracked. Do I need to replace the entire headlamp assembly, or can I get away with swapping out just the lens? Also, I can easily remove the top clips, but I can't get to the lower ones unless (apparently) I remove much more stuff. Are there detailed instructions anywhere on how to do this? Thanks. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted December 9, 2010 Report Share Posted December 9, 2010 You can replace lens without replacing the assembly. You will need to remove the head light though, but you will have to take off the front bumper to access the headlight bolts. Link to comment Share on other sites More sharing options...
