O_0 Posted December 19, 2010 Report Share Posted December 19, 2010 I am looking into doing either all mounts in poly or most in poly and a couple made solid. Does anyone make these or know of a good 'how to'? Don't need the opinions on why I shouldn't do it, I already know what to expect as I have a few vehicles containing torque plates, solid mounting, chain wrapped mounts, filled mounts.... I am sure you get the point, so if you could help steer me in the direction I am looking for that would be of great help. :pizza: :pizza: Itsa 97 2.4 Turbo Wagon.. :D Link to comment Share on other sites More sharing options...
socal850tuner Posted December 19, 2010 Report Share Posted December 19, 2010 IPD makes the upper engine mount, firewall mount, and trans mount in poly. There are some swedish companies that make solid subframe mounts, but to my knowledge no one makes solid,poly,delring front, rear, or passenger side engine mounts. Link to comment Share on other sites More sharing options...
krn Posted December 19, 2010 Report Share Posted December 19, 2010 IPD has poly upper and lower mounts. ipdusa.com CJ Youthers has subframe mounts: http://www.yother.com/cj-per-brakes-02.html Eurposport tuning has control arms bushings: http://www.eurosporttuning.ca/mm5/merchant.mvc?Screen=PROD&Store_Code=EST02&Product_Code=PFF88-101&Category_Code=VL-S70-su Used set: http://forums.swedespeed.com/showthread.php?149473-Eurosport-Tuning-Front-Control-Arm-Bushings Chassis bracing: http://www.vivaperformance.com/categories/Volvo/S70-classic/Suspension/ Thread here on using caulk to stiffen motor mounts: http://volvospeed.com/vs_forum/index.php/topic/138954-3m-window-weld/ Link to comment Share on other sites More sharing options...
jadnhm Posted December 20, 2010 Report Share Posted December 20, 2010 Thread here on using caulk to stiffen motor mounts: http://volvospeed.com/vs_forum/index.php/topic/138954-3m-window-weld/ It's not 'caulk' per se though it comes in the same type of packaging. It's polyurethane. Hey does anyone know if there are poly versions of the front control arm mounts for AWD - or ideas on how you might make them? Link to comment Share on other sites More sharing options...
O_0 Posted December 20, 2010 Author Report Share Posted December 20, 2010 Cool beans, I'll surf more into it in the AM. I am beat from a long drive today. :D Link to comment Share on other sites More sharing options...
O_0 Posted December 24, 2010 Author Report Share Posted December 24, 2010 They didnt have anything that would be of what I am looking for. :( Link to comment Share on other sites More sharing options...
iBoost Posted December 26, 2010 Report Share Posted December 26, 2010 For the Firewall mount an IPD transmission mount will work perfectly, you just need to order 2 of the metal inserts and cut the second to size vwala, firewall mount ;) Link to comment Share on other sites More sharing options...
