Ipd Posted January 10, 2011 Author Report Share Posted January 10, 2011 Here's the final prototype. Used vinyl letters to label the intake "I" and exhaust "E" "A" and "R" mean advance and retard respectively. Bolt holes are nearly a zero fit so you should be able to get accuracies to within a tenth of a degree. One tool does both intake and exhaust. Labeling Ok you think? Had planned on having the laser just cut the letters out or maybe have it laser etched on the black oxide for nice contrast. Speak now if you got better ideas.... Commissar this one's heading your way! Link to comment Share on other sites More sharing options...
lookforjoe Posted January 10, 2011 Report Share Posted January 10, 2011 Here's the final prototype. Labeling Ok you think? Had planned on having the laser just cut the letters out or maybe have it laser etched on the black oxide for nice contrast. Speak now if you got better ideas.... Letters are too large & don't need to be "bold" - distracting. Link to comment Share on other sites More sharing options...
wizzard_al Posted January 12, 2011 Report Share Posted January 12, 2011 Letters are too large & don't need to be "bold" - distracting. Personally, if I had to choose the lettering and numbering, I'd want something like this on the numbers: ------------|--|--|--|--|--|--| ------------/--|--|--|--|--|--\ ------A---/--/---|--|--|---\--\----R ----------/--4----|--|--|----4--\ ---------6-------2--|--2--------6 ----------------------| ----------------------0 This would make it a lot easier to read the numbers, instead of simply sighting the numbers so closely. And I think letters half the size Lucky proposed would work. ARGH, the post doesn't look like what I wanted. Had to add the horizontal lines, this editor doesn't allow spaces to be used as blank spaces. Link to comment Share on other sites More sharing options...
the commissar! Posted January 12, 2011 Report Share Posted January 12, 2011 Here's the final prototype. Used vinyl letters to label the intake "I" and exhaust "E" "A" and "R" mean advance and retard respectively. Bolt holes are nearly a zero fit so you should be able to get accuracies to within a tenth of a degree. One tool does both intake and exhaust. Labeling Ok you think? Had planned on having the laser just cut the letters out or maybe have it laser etched on the black oxide for nice contrast. Speak now if you got better ideas.... Commissar this one's heading your way! Completely functional looking... The huge letters are overkill (and ugly ), maybe some etched and painted 12pt font with "Intake" and "Exhaust" and "Advance" and "Retard". I think to have each line identified by a number would clutter it up too much. Perhaps simply having every other line a mm longer so you could easily identify the +/- 2/4/6 points. The biggest problem with the other two solutions I've used was the slop. Second to that is the scale on the one. If this one overcomes the slop then it is a winner and all else is just aesthetics. Look forward to playing with the new tool! Link to comment Share on other sites More sharing options...
Ipd Posted January 12, 2011 Author Report Share Posted January 12, 2011 Great input, thanks guys! Commissar i shipped one out to you yesterday Link to comment Share on other sites More sharing options...
the commissar! Posted January 12, 2011 Report Share Posted January 12, 2011 Great input, thanks guys! Commissar i shipped one out to you yesterday Thanks Lucky! Link to comment Share on other sites More sharing options...
Homer Posted January 13, 2011 Report Share Posted January 13, 2011 I'll take one for sure. Link to comment Share on other sites More sharing options...
Serge Posted January 14, 2011 Report Share Posted January 14, 2011 Can't wait for these! Link to comment Share on other sites More sharing options...
Snabb T5M Posted January 16, 2011 Report Share Posted January 16, 2011 Count me in for one!! When I get the NA cams installed this will come in handy to get the most out of them. Link to comment Share on other sites More sharing options...
TorqueSteer Posted January 17, 2011 Report Share Posted January 17, 2011 Count me in for one!! When I get the NA cams installed this will come in handy to get the most out of them. Absolutely. When I first installed the NA cams, I wasn't too impressed, but after fiddling with the cam timing, I was blown away by the difference. Link to comment Share on other sites More sharing options...
boxpin Posted January 17, 2011 Report Share Posted January 17, 2011 Count me in. Link to comment Share on other sites More sharing options...
flaco Posted January 17, 2011 Report Share Posted January 17, 2011 Absolutely. When I first installed the NA cams, I wasn't too impressed, but after fiddling with the cam timing, I was blown away by the difference. What did you do to timing? Advance / retard intake / exhaust both? Link to comment Share on other sites More sharing options...
lookforjoe Posted January 18, 2011 Report Share Posted January 18, 2011 What did you do to timing? Advance / retard intake / exhaust both? I won't speak for TS, but in my case, I wanted better breathing up top with the larger turbo, so I retarded the exhaust cam (much more than I thought, as it turns out! ) The stock setup is approx 4º adv. Exh 0º Int - mine is now 2º adv. Exh, 2º retarded Int. This may all change with the better breathing later head, I don't know. Link to comment Share on other sites More sharing options...
98t5M Posted January 18, 2011 Report Share Posted January 18, 2011 Absolutely. When I first installed the NA cams, I wasn't too impressed, but after fiddling with the cam timing, I was blown away by the difference. Please do share what your magical numbers were. Obviously we have very different setups but I'm just curious what worked well for you. I kind of feel like any benefit the NA cams should be giving me is negated by the excess overlap. Link to comment Share on other sites More sharing options...
dublin14 Posted January 18, 2011 Report Share Posted January 18, 2011 Whats going to be REALLY interesting is to see what all the guys thought they had with the OBM or other compared to the IPD CTT. Link to comment Share on other sites More sharing options...
