turbomike89 Posted January 21, 2011 Report Share Posted January 21, 2011 hey guys! Im workin on my 2000 s40 and i just did a head job and was turning over the car a couple times and now it wont go to position 3 or START. What happened? Is it a safety feature? Link to comment Share on other sites More sharing options...
flyfishing3 Posted January 21, 2011 Report Share Posted January 21, 2011 if you don't get the answer you need here. try here Link to comment Share on other sites More sharing options...
loseR99 Posted January 21, 2011 Report Share Posted January 21, 2011 Verify that you reconnected the IAC connector, and properly connected the coil leads and coils. Also make sure the the harness is properly grounded to the cam cover, there should be a ring terminal coming off of the harness that bolts to the cam cover between cylinder 1 & 2. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted January 24, 2011 Report Share Posted January 24, 2011 Let me clarify, the engine cranks but does not start? Any codes stored? Have you verified fuel, compression, and spark? Link to comment Share on other sites More sharing options...
