DouginDenver Posted January 29, 2011 Report Share Posted January 29, 2011 99 C70. I removed the one bolt at the front and two sideways bolts by the AC comrpressor so the alternator is now loose. I also removed the three bolts holding the PS pump to allow it to lift a bit. Do I need to get the main red cable off the back before I can move it (I was hoping to get a bit more room)? But how does it actually come out? What all do I need to remove or loosen to give it clearance? Link to comment Share on other sites More sharing options...
DouginDenver Posted January 29, 2011 Author Report Share Posted January 29, 2011 As I look at it more, what is keeping it from coming out are the two parts of the casting that go behind the AC compressor - I can't lift it enough for those to clear. Do I need to drop the compressor too? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted January 29, 2011 Report Share Posted January 29, 2011 You need to loosen the lower 2 a/c compressor bolts. Lift out from the top. I'll warn you, it's a bit tricky. Removing the upper radiator hose gives you a little more clearance. Link to comment Share on other sites More sharing options...
Dan A Posted January 30, 2011 Report Share Posted January 30, 2011 Yeah, loosen but not drop completely. Link to comment Share on other sites More sharing options...
