VolvoRine Posted February 13, 2011 Report Share Posted February 13, 2011 Hey guys I built a "Supercomputer" back in December 2007 with top notch parts back then...at the beginning everything was working "aite" until the blue screen started coming up every now and then, it was frustrating and I was going loco! I decided to sent everything (except the video card) to warranty just to double check that it wasn't a defective part...after numerous tries I gave up and left the computer in the dust and got myself a laptop.. which is currently being repaired cuz I dropped it and the hard drive went bad! but that's another story No I've decided to fix the old "Supercomputer" and hopefully use it for a while, this is one of the errors that I come across everyday when I use my PC Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional information about the problem: BCCode: fc BCP1: 8E3A2AD8 BCP2: 7B1D6963 BCP3: 8E3A2A6C BCP4: 00000002 OS Version: 6_1_7600 Service Pack: 0_0 Product: 256_1 Files that help describe the problem: C:\Windows\Minidump\021311-18033-01.dmp C:\Users\Julio\AppData\Local\Temp\WER-31543-0.sysdata.xml Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt Any comments or advices are welcome! Thanks Link to comment Share on other sites More sharing options...
Kevin. Posted February 13, 2011 Report Share Posted February 13, 2011 I was checking the a ... specs on the end line, for the rotary, girder....I'm retarded Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted February 13, 2011 Report Share Posted February 13, 2011 Was the memory RMA'ed in your "warranty everything" approach? Does the motherboard have onboard video? Pull the video card and run off the onboard video. IF that fixes, I'd think it points to a bad gfx card or driver problems. And lastly, Have you tried reformatting the computer? Could be a corrupt driver. Link to comment Share on other sites More sharing options...
VolvoRine Posted February 13, 2011 Author Report Share Posted February 13, 2011 Specs should help........ AMD ATHLON 64 X2 DUAL CORE PROCESSOR 6400+ 3.21 GHz Ultra X-Wind Aluminum Socket 478/754/939/940/AM2 CPU Cooling Fan MB ASUS M2N-SLI Deluxe NF570SLI AM2 VGA EVGA 512-P2-N773-AR 8600GTS 512 MEM 1Gx2|PATRIOT 240P PDC22G6400LLK HD 320G|ST 7K ATA100 ST3320620AV I Formatted the computer already last week and still same problem.. :( Link to comment Share on other sites More sharing options...
info2x Posted February 13, 2011 Report Share Posted February 13, 2011 What is going on just before the blue screen? Does safemode work properly? Link to comment Share on other sites More sharing options...
VolvoRine Posted February 13, 2011 Author Report Share Posted February 13, 2011 crucial.com report http://www.crucial.com/systemscanner/viewscanbyid.aspx?id=9645F66731D926C3 What is going on just before the blue screen? Does safemode work properly? haven't tried safe mode... Link to comment Share on other sites More sharing options...
PyROTech Posted February 14, 2011 Report Share Posted February 14, 2011 ok, reinstall os, see if that fixes the problem. probably your ram or some driver/program Link to comment Share on other sites More sharing options...
dereswyman Posted February 14, 2011 Report Share Posted February 14, 2011 I agree with everyone else, its probably a driver error or faulty hardware. It would be nice if you could get a bit more info from the BSOD. Here's a link to a BSOD log reader. Can you post the filename and the error name? http://www.nirsoft.net/utils/blue_screen_view.html Just a thought, did you install the chipset driver for your mobo? Link to comment Share on other sites More sharing options...
VolvoRine Posted February 14, 2011 Author Report Share Posted February 14, 2011 ok, reinstall os, see if that fixes the problem. probably your ram or some driver/program I reinslalled the OS with Windows 7, had WIndows Vista before Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted February 14, 2011 Report Share Posted February 14, 2011 I reinslalled the OS with Windows 7, had WIndows Vista before So the question still remains: Was the memory RMA'ed in your "warranty everything" approach? Does the motherboard have onboard video? Pull the video card and run off the onboard video. IF that fixes, I'd think it points to a bad gfx Bad memory or bad gfx card? Link to comment Share on other sites More sharing options...
VolvoRine Posted February 15, 2011 Author Report Share Posted February 15, 2011 Was the memory RMA'ed in your "warranty everything" approach? Does the motherboard have onboard video? Pull the video card and run off the onboard video. IF that fixes, I'd think it points to a bad gfx card or driver problems. And lastly, Have you tried reformatting the computer? Could be a corrupt driver. The motherboard has not onboard video IIRC as far as the memory I returned them and bought new ones... G skill instead of the patriots previously installed on it Link to comment Share on other sites More sharing options...
