thewhiteguy1 Posted February 14, 2011 Report Share Posted February 14, 2011 still getting misfire codes after replacing plugs and plug wires.. could it be that i need a new distributor/cap???? <_< Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted February 14, 2011 Report Share Posted February 14, 2011 Yep, especially if you haven't replaced it in a while. A while being ~30k+ Otherwise, what did you gap your plugs at? And I'm assuming you're getting multiple misfires, not just on one cylinder. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted February 14, 2011 Report Share Posted February 14, 2011 cap and rotor is probably a good idea. How many cylinders are misfiring? What brand plugs/wires did you use? Link to comment Share on other sites More sharing options...
mrbrightside2009 Posted February 14, 2011 Report Share Posted February 14, 2011 yes my dist. cap/rotor had just 20k on them, had a misfire at high rpm, replaced them and all is good now, i noticed on my rotor it had burnt/black marks on the metal contacts. Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted February 14, 2011 Author Report Share Posted February 14, 2011 Yep, especially if you haven't replaced it in a while. A while being ~30k+ Otherwise, what did you gap your plugs at? And I'm assuming you're getting multiple misfires, not just on one cylinder. yes multiple misfires. i haven't owned the car for the 30k+ so i am not sure when it was last replaced. oem plugs (haven't been gapped because i lost my gapper) normal gap is like .028 right? and kingsborne 8mm plug wires. Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted February 14, 2011 Report Share Posted February 14, 2011 Wouldn't hurt to check the gap, but they are probably gapped fine. I'd bet it's the dist cap/rotor. Link to comment Share on other sites More sharing options...
T5power Posted February 14, 2011 Report Share Posted February 14, 2011 i agree. ignition systems on these cars are pretty easy to work with. all of your components are pretty much in front of you. if plugs and wires don't do it, it's generally cap and rotor. the coils don't commonly fail :) Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted February 14, 2011 Author Report Share Posted February 14, 2011 i agree. ignition systems on these cars are pretty easy to work with. all of your components are pretty much in front of you. if plugs and wires don't do it, it's generally cap and rotor. the coils don't commonly fail fcp here i come! Link to comment Share on other sites More sharing options...
B_Dub Posted February 15, 2011 Report Share Posted February 15, 2011 I was getting misfires AFTER new cap/rotor, plugs, plugwires, and MSD coils installed... Couldn't figure it out at first but found it to be a bad cam sensor. But I bet your problem is solved with new cap& rotor. Link to comment Share on other sites More sharing options...
