thewhiteguy1 Posted February 22, 2011 Report Share Posted February 22, 2011 http://s6.photobucket.com/albums/y213/thewhiteguy1/?action=view¤t=253f340c.mp4 talked about it in chat, brett says it might be a cracked manifold/exh housing, others say turbo help? Link to comment Share on other sites More sharing options...
FCP Euro Posted February 23, 2011 Report Share Posted February 23, 2011 Could be the turbo rubbing against the housing. Check to see how much shaft play is in it. Link to comment Share on other sites More sharing options...
Oreo931 Posted February 23, 2011 Report Share Posted February 23, 2011 Sounds like your turbo is bad/going bad. Link to comment Share on other sites More sharing options...
WayAway Posted February 23, 2011 Report Share Posted February 23, 2011 Might be a long shot but P/S pump Link to comment Share on other sites More sharing options...
fastwagonhawaii Posted February 23, 2011 Report Share Posted February 23, 2011 Might be a long shot but P/S pump I think i might have to agree, when my power steering pump went out, thats what it sounded like. does spool normally, usually if you are having that much friction with in the turbo it spool as fast if at all. If your engine feels normal then I would say power steering pump. Link to comment Share on other sites More sharing options...
--Aaron-- Posted February 23, 2011 Report Share Posted February 23, 2011 Sounds like your turbo is bad/going bad. That is what I'm thinking as well. Check your turbo for excessive shaft play ASAP. Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted April 10, 2011 Author Report Share Posted April 10, 2011 so i replaced turbo and manifold, and am still getting this noise, only after 4k rpms though anything? Link to comment Share on other sites More sharing options...
bergmjs Posted April 10, 2011 Report Share Posted April 10, 2011 Unhook the wastegate arm off the wastegate itself and drive it a little bit. If you can still get the noise with the turbo not spooling at all, then you know it's not the turbo. Link to comment Share on other sites More sharing options...
