Slater Posted February 20, 2005 Author Report Share Posted February 20, 2005 OK.I checked out the cable.It does not appear that it will work.The negative terminals on the RCA plugs don't seem to be hooked to anything.They should go to the amp for a common-ground configuration, shouldn't they?Then the ground wires go to from the amp to the chassis, right?I wanted to install the eclipse 3424.Please help -Confused in Colorado←Depends on the head unit. The stock amp expects a non-isolated ground. Most head units have isolated RCA grounds, some don't. Depends on what you need. By grounding the amp to head unit chassis, you get the identical non-isolated ground.I made the cable for the most head unit scenerio, and can make a cable with the RCA grounds connected if you want.I assume you followed the directions and attached the ground according to the directions?- Slater Link to comment Share on other sites More sharing options...
JeffW Posted February 20, 2005 Report Share Posted February 20, 2005 Depends on the head unit. The stock amp expects a non-isolated ground. Most head units have isolated RCA grounds, some don't. Depends on what you need. By grounding the amp to head unit chassis, you get the identical non-isolated ground.I made the cable for the most head unit scenerio, and can make a cable with the RCA grounds connected if you want.I assume you followed the directions and attached the ground according to the directions?- Slater←That's my issue right now.Since the HU ground doesn't go to the amp, I won't have a common (non-isolated) ground.I haven't attached anything, because I'm basing my purchase on what works.I would like to go with eclipse, though.Thank a million, man.You are the ONLY person who has been ANY help in this matter. Link to comment Share on other sites More sharing options...
Guest DougK Posted February 20, 2005 Report Share Posted February 20, 2005 Got Slaters kit in the mail (I guess the other day, just got home from vacation). Looks to be top notch... if my T5R would ever get here (grr).Thought'd I'd share Link to comment Share on other sites More sharing options...
Veneficus Posted February 20, 2005 Report Share Posted February 20, 2005 Got Slaters kit in the mail (I guess the other day, just got home from vacation). Looks to be top notch... if my T5R would ever get here (grr).Thought'd I'd share←Not going aftermarket with the head unit doug? Link to comment Share on other sites More sharing options...
Guest DougK Posted February 21, 2005 Report Share Posted February 21, 2005 Not going aftermarket with the head unit doug?←No, this goes the other way. aftermarket HU to oem amp.. Link to comment Share on other sites More sharing options...
Veneficus Posted February 21, 2005 Report Share Posted February 21, 2005 No, this goes the other way. aftermarket HU to oem amp..←Oooh, thats interesting. Good deal. Link to comment Share on other sites More sharing options...
Vos Posted February 21, 2005 Report Share Posted February 21, 2005 Any idea on what pre-amp voltage the stock amp is looking for? 2V or 4V are options I have seen on various HU's...Got my adapter in the mail last week, waiting to buy a new HU till I make sure I have everything spec'ed out correctly :) Link to comment Share on other sites More sharing options...
lightsandsirens Posted February 26, 2005 Report Share Posted February 26, 2005 Got mine a few days ago! Thanks a lot. Now I'm out to find a nice HU :D Link to comment Share on other sites More sharing options...
Vos Posted February 27, 2005 Report Share Posted February 27, 2005 Any idea on what pre-amp voltage the stock amp is looking for? 2V or 4V are options I have seen on various HU's...Got my adapter in the mail last week, waiting to buy a new HU till I make sure I have everything spec'ed out correctly ←Installed my Alpine 9831 HU this week, using Slaters adapter, and though it worked great, I had some RPM related alternator whine. Slater was very helpful in getting it figured out.I ended up first on my own just installing a noise filter on the 12V suppply to the HU, which helped, but did not solve it. I then put ferrites on the RCA cables, helped more, but not a complete solution either.I then got real frustrated, and cut up the OEM DIN plug and Slater's adapter, and wired things directly, but did not use the DIN cable shielding. No worse, but no better.Finally I did what I should have done to begin with and asked Slater for help. His recommendation was to connect the RCA shields with the OEM DIN cable's shielding.With his help I got it solved! The problem with my setup is that the HU wanted the RCA shielding for each channel connected to the DIN cable shielding for each channel, and I also grounded the DIN cable shielding comming off of the ground and remote turn on wires to the HU chasis for good measure. My amp ground cable is on the HU chasis as well. No more noise! I guess that means that for Alpine HU's Slater would want his adapter to have the RCA grounds connected to the DIN plug's outer metal coupler, which on the OEM harness connects to the cable shielding, and have users ground to the HU chasis...Now I am truly enjoying some tunes The 9831 was a bit of a pain to figure out, but once I got it tuned correctly it sounds awesome.Thanks for the help! B) Link to comment Share on other sites More sharing options...
Slater Posted February 27, 2005 Author Report Share Posted February 27, 2005 Installed my Alpine 9831 HU this week, using Slaters adapter, and though it worked great, I had some RPM related alternator whine. Slater was very helpful in getting it figured out.I ended up first on my own just installing a noise filter on the 12V suppply to the HU, which helped, but did not solve it. I then put ferrites on the RCA cables, helped more, but not a complete solution either.I then got real frustrated, and cut up the OEM DIN plug and Slater's adapter, and wired things directly, but did not use the DIN cable shielding. No worse, but no better.Finally I did what I should have done to begin with and asked Slater for help. His recommendation was to connect the RCA shields with the OEM DIN cable's shielding.With his help I got it solved! The problem with my setup is that the HU wanted the RCA shielding for each channel connected to the DIN cable shielding for each channel, and I also grounded the DIN cable shielding comming off of the ground and remote turn on wires to the HU chasis for good measure. My amp ground cable is on the HU chasis as well. No more noise! I guess that means that for Alpine HU's Slater would want his adapter to have the RCA grounds connected to the DIN plug's outer metal coupler, which on the OEM harness connects to the cable shielding, and have users ground to the HU chasis...Now I am truly enjoying some tunes The 9831 was a bit of a pain to figure out, but once I got it tuned correctly it sounds awesome.Thanks for the help! ←Awesome! Yeah, I can make the cable you speak of. It's for the minority of HUs out there, including Alpines, that expect non-isolated grounds on the RCAs. It must be an Apline thing, because the stock amp is Alpine as well.Anways, the non-isloated cable is no problem - just specify when ordering which one you want/need.- Slater Link to comment Share on other sites More sharing options...
1buysellnow1 Posted November 25, 2006 Report Share Posted November 25, 2006 Great Idea! Let me know when they are available.SOORY ABOUT THE HI CAPS, BUT MY KEYBOARD BROKE. I BOUGHT A 2000 VOLVO S80 2.9. IT HAD AN AFTER MARKER RADIO. I REMOVED IN AND PURCHASED OEM HU-810 6 DISC CD PLAYER. I HOOK UP THE PLUGS IN THE BACK BUT HAD NO SOUND. I LOOKED WHERE THE AFTER MARKET RADIO WAS AND SEEN A BUNCH OF CUT SPEAKER WIRES. LOOKS LIKE A FACTORY PLUG WAS CUT FROM ALL THE WIRES. I DO NOT KNOW WHERE TO HOOK THEM UP TO. ANY IDES? I WAS TOLD TO LOOK FOR A FACTORY AMP UNDER THE SEATS. DID NOT FIND ONE. WHATS NEXT. ANY WAY TO SPLICE THE SPEAKER WIRES TO THE OEM VOLVO RADIO? PLEASE HELLP. I JUST PAID $300 FOR THE EOM VOLVO RADIO. LIKE I SAID I GOT POWER RADIO WORKS, STEERING WHEEL CONTROLS WORK, BUT DO NOT KNOW WHERE TO HOOK UP THE SPEAKERS. PLEASE HELP. MY EMAIL IS HKOSAKOWSKI@COX.NET PLEASE HELP. WHEAT SHOULD I DO. I CANOOT RETURN THE RADIO. SHOULD I BUY OEM AMP, OR WHAT. IF I DO BUY ONE HOW DO I CONNECT IT. THE SPEAKERS WIRES ARE THERE EXCEPT SOMEONE CUT THE EOM PLUG THAT GOES TO THE OEM VOLVO RADIO AND SPLICED THEM INTO THE AFTERMARKET. SO HOW CAN I CONNECT THE SPEAKERS...PLEASE HELP....SOORY ABOUT THE HI CAPS, BUT MY KEYBOARD BROKE. I BOUGHT A 2000 VOLVO S80 2.9. IT HAD AN AFTER MARKER RADIO. I REMOVED IN AND PURCHASED OEM HU-810 6 DISC CD PLAYER. I HOOK UP THE PLUGS IN THE BACK BUT HAD NO SOUND. I LOOKED WHERE THE AFTER MARKET RADIO WAS AND SEEN A BUNCH OF CUT SPEAKER WIRES. LOOKS LIKE A FACTORY PLUG WAS CUT FROM ALL THE WIRES. I DO NOT KNOW WHERE TO HOOK THEM UP TO. ANY IDES? I WAS TOLD TO LOOK FOR A FACTORY AMP UNDER THE SEATS. DID NOT FIND ONE. WHATS NEXT. ANY WAY TO SPLICE THE SPEAKER WIRES TO THE OEM VOLVO RADIO? PLEASE HELLP. I JUST PAID $300 FOR THE EOM VOLVO RADIO. LIKE I SAID I GOT POWER RADIO WORKS, STEERING WHEEL CONTROLS WORK, BUT DO NOT KNOW WHERE TO HOOK UP THE SPEAKERS. PLEASE HELP. MY EMAIL IS HKOSAKOWSKI@COX.NET PLEASE HELP. WHEAT SHOULD I DO. I CANOOT RETURN THE RADIO. SHOULD I BUY OEM AMP, OR WHAT. IF I DO BUY ONE HOW DO I CONNECT IT. THE SPEAKERS WIRES ARE THERE EXCEPT SOMEONE CUT THE EOM PLUG THAT GOES TO THE OEM VOLVO RADIO AND SPLICED THEM INTO THE AFTERMARKET. SO HOW CAN I CONNECT THE SPEAKERS...PLEASE HELP.... Link to comment Share on other sites More sharing options...
CiDirkona Posted November 27, 2006 Report Share Posted November 27, 2006 Are these still available? I'll be putting a new head unit in my '94 850, and after hearing the horror stories around in doing so, one of these adaptors might be handy to have! -Colin Link to comment Share on other sites More sharing options...
Slater Posted December 4, 2006 Author Report Share Posted December 4, 2006 Are these still available? I'll be putting a new head unit in my '94 850, and after hearing the horror stories around in doing so, one of these adaptors might be handy to have! -ColinYes, they are still available!Please visit our website at http://www.quickbrickmotorsports.com/Thanks! Link to comment Share on other sites More sharing options...
greyboy Posted January 28, 2007 Report Share Posted January 28, 2007 Yes, they are still available!Please visit our website at http://www.quickbrickmotorsports.com/Thanks!Slater,How do I go about getting a little "tech support" for a setup using your HU->factory amp adapter? I bought a used 1998 V70R in November and had to pull the "Radio/Amplifier" fuse since the battery drained every night so the care wouldn't start. I pulled the HU out and I didn't see anything obvious, but I was hoping you might have some insight into what I could look for or trace for the cause of this. I hate driving around with no HU!-N Link to comment Share on other sites More sharing options...
