gottago Posted March 1, 2011 Report Share Posted March 1, 2011 Once again I am seeking help with wife's 01 V70 XC, low coolant light came on and resevoir was a little low, filled, while later light came on again and was little low. After eyeballing usual suspects, rad, radhoses, head/block area, found coolant residue on left (drivers side) heater hose at firewall. So I need to replace both heater hoses, I've looked and having a hard time seeing where the hoses connect to the engine. How hard is this to do in my driveway and how long should I expect to spend doing this. Any help/feedback will be truly appreciated. Thank You Link to comment Share on other sites More sharing options...
FCP Euro Posted March 2, 2011 Report Share Posted March 2, 2011 They connect to a hard metal line just next to the turbo. The lines are not hard to replace at all and if you do a search, I am sure there is a how-to somewhere. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted March 2, 2011 Report Share Posted March 2, 2011 Remove the hard plastic fresh air hose that runs from the airbox to the turbo and you'll easily be able to access the heater hoses. Link to comment Share on other sites More sharing options...
