Svenska Posted March 16, 2011 Report Share Posted March 16, 2011 RE: a 1999 XC70 AWD The driver's door suddenly doesn't open at all. The key fob makes the vertical door lock post go up & down, but the door doesn't open. The chrome inner door handle pulls out like you would expect it and the exterior door handle pulls outward but it has no effect. Obviously the mechanism has failed, my question is how do you get the door panel off to replace it if you can't open the door??? Link to comment Share on other sites More sharing options...
FCP Euro Posted March 17, 2011 Report Share Posted March 17, 2011 If you pull the handle in the car, does the door open? If not, then you will definitely need to remove the door handle but it will not be easy. Link to comment Share on other sites More sharing options...
Svenska Posted March 17, 2011 Author Report Share Posted March 17, 2011 No, it doesn't open from the inside or the outside. I've never seen anything like this before. Usually you can open it from outside or inside... Link to comment Share on other sites More sharing options...
FCP Euro Posted March 26, 2011 Report Share Posted March 26, 2011 The latch itself must be bad. Either that or it has become disconnected some how. You will need to get the door panel off or the door open somehow to get a better look. I know this is easier said then done. Good Luck and let us know if you make any progress. Link to comment Share on other sites More sharing options...
