98glt-5 Posted March 27, 2011 Report Share Posted March 27, 2011 In the middle of a swap, im pretty sure the new tranny has a speed sensor, near the right axle, only thing is, plug is different from the auto one, what do you guys do in this situation? thanks. Link to comment Share on other sites More sharing options...
Black Betty Posted March 27, 2011 Report Share Posted March 27, 2011 What year is the trans and what year is the car? You may have to just pick up the speed from the abs ring on the axle depending the year of the trans/car. Link to comment Share on other sites More sharing options...
gilber33 Posted March 27, 2011 Report Share Posted March 27, 2011 If the trans has a speed sensor on it, then it's an M56L and you'll have to tap the wires into the transmission wiring harness to get to get the speed signal. Link to comment Share on other sites More sharing options...
jnderr Posted March 27, 2011 Report Share Posted March 27, 2011 Looks like you are swapping into a 98? Which means you should not have to do anything as that year did not have a trans speed sensor. Correct me if I am wrong. Link to comment Share on other sites More sharing options...
95 854 t-5 Posted March 27, 2011 Report Share Posted March 27, 2011 Negative on the L I have an H w/ speed sensor (95). +1 to tapping the abs signal Link to comment Share on other sites More sharing options...
lookforjoe Posted March 27, 2011 Report Share Posted March 27, 2011 Looks like you are swapping into a 98? Which means you should not have to do anything as that year did not have a trans speed sensor. Correct me if I am wrong. This is correct, if the oP is doing the swap on the '98 listed in the sig. NO speed sensor used for '98, speed signal comes from ABS on '98 Link to comment Share on other sites More sharing options...
gilber33 Posted March 27, 2011 Report Share Posted March 27, 2011 Yeah, go for the ABS, sorry, got my thought process mixed up. ;) Link to comment Share on other sites More sharing options...
98glt-5 Posted March 27, 2011 Author Report Share Posted March 27, 2011 Thanks for all the responses guys, yeah I realized that when i took it up the road, speedo worked, i was like how the hell is this thing working, but now I know 98 doesnt need a speed sensor. Link to comment Share on other sites More sharing options...
