scandalo Posted March 27, 2011 Report Share Posted March 27, 2011 Changed rear cam seal. Couldn't get it out. Disconnected distributor from coil. Left cam sensor connected. Cranked system to attempt to loosen seal (futile and stupid). Car won't start. Tries once and spits like its rich with little spark. Not going to go much farther than that. Figure the ECU is confused. I did this yesterday and did not try to start it until about an hour ago. Did I short the sensor? Kill the coil? Give me some insight. I will try to swap CPS with a good working unit later. Link to comment Share on other sites More sharing options...
Tommy. Posted March 27, 2011 Report Share Posted March 27, 2011 Changed rear cam seal. Couldn't get it out. Disconnected distributor from coil. Left cam sensor connected. Cranked system to attempt to loosen seal (futile and stupid). Car won't start. Tries once and spits like its rich with little spark. Not going to go much farther than that. Did I short the sensor? Kill the coil? Give me some insight. I will try to swap CPS with a good working unit later. I wish I could help but a lot of what you said is still foreign language to me sorry to hear that stu hopefully someone can help! Link to comment Share on other sites More sharing options...
scandalo Posted March 27, 2011 Author Report Share Posted March 27, 2011 I'm convinced I killed the sensor (makes the most sense). I just wanna spitball and see if anyone knows whats up. Link to comment Share on other sites More sharing options...
info2x Posted March 27, 2011 Report Share Posted March 27, 2011 You probably flooded the cylinders Link to comment Share on other sites More sharing options...
scandalo Posted March 27, 2011 Author Report Share Posted March 27, 2011 You probably flooded the cylinders Haven't really cranked it enough for that but I can check that just in case. I cranked about 3-5 times while the CPS was disconnected haven't really done it more than that. I should add that I did this yesterday and did not try to start it until about an hour ago. Link to comment Share on other sites More sharing options...
