Jack8745 Posted April 4, 2011 Report Share Posted April 4, 2011 so i finally got around to installing some parts that were sitting around installed the NA TB and ipd intake spacer. i also redid my pcv catch can so now its like this now the car jumps between 1500-1700rpm when in park no codes are on before i installed the TB i had the TB positioning sensor off. could have this caused my problem thanks Link to comment Share on other sites More sharing options...
Jack8745 Posted April 4, 2011 Author Report Share Posted April 4, 2011 so i finally got around to installing some parts that were sitting around installed the NA TB and ipd intake spacer. i also redid my pcv catch can so now its like this now the car jumps between 1500-1700rpm when in park no codes are on before i installed the TB i had the TB positioning sensor off. could have this caused my problem thanks ps its not the linkage because the car does this with the linkage disconnected Link to comment Share on other sites More sharing options...
the commissar! Posted April 4, 2011 Report Share Posted April 4, 2011 Is it possible you mucked up the install of the bracket talked about in this thread...that happens a lot. Also did you use a IM gasket on each side of the spacer? Check all vacuum lines? Check that hose from the vac tree to the IAC valve. They die when they get old... Link to comment Share on other sites More sharing options...
Jack8745 Posted April 4, 2011 Author Report Share Posted April 4, 2011 i figured it out. the idle set screw on the 960 tb not adjusted for the 850 tb linkage adjusted it; runs fine now Link to comment Share on other sites More sharing options...
Q-Ship Posted April 4, 2011 Report Share Posted April 4, 2011 how do you like it? */- ? appreciable differences? Link to comment Share on other sites More sharing options...
Jack8745 Posted April 5, 2011 Author Report Share Posted April 5, 2011 i feel a difference so thats a + is it a big difference ? hard to tell, this is my wifes dd and i sometimes drive it. The test will come if she can tell something is improved, if she can tell without me telling her then its a big + i did it because its an easy and a cheap upgrade (got all the parts from a local junk yard) the most fun i had was cleaning up the casting marks on the intake and gasket matching it. now my intake matches my valve cover By jack8745 at 2011-04-04 ps i would do it again; all the little stuff just adds to the car Link to comment Share on other sites More sharing options...
Q-Ship Posted April 6, 2011 Report Share Posted April 6, 2011 totally agree. I've heard a couple of people complain that the bigger TB + manifold messed up their throttle tip in, so I was wondering your (+your wife's!) driving impressions. Link to comment Share on other sites More sharing options...
the commissar! Posted April 6, 2011 Report Share Posted April 6, 2011 For every there is a ...it is a cheap easy mod and if you like it great and if not it is completely reversible...I like and kept mine but I like my Tahoe too...:o Link to comment Share on other sites More sharing options...
Jack8745 Posted April 6, 2011 Author Report Share Posted April 6, 2011 totally agree. I've heard a couple of people complain that the bigger TB + manifold messed up their throttle tip in, so I was wondering your (+your wife's!) driving impressions. throttle tip in - what is that ? For every there is a ...it is a cheap easy mod and if you like it great and if not it is completely reversible...I like and kept mine but I like my Tahoe too... Tahoe - what is that? Link to comment Share on other sites More sharing options...
theForgottenone Posted April 6, 2011 Report Share Posted April 6, 2011 Tahoe - what is that? something made by chevy :lol: Link to comment Share on other sites More sharing options...
Jack8745 Posted April 6, 2011 Author Report Share Posted April 6, 2011 something made by chevy also a lake in ca/nv Link to comment Share on other sites More sharing options...
