FAST850R Posted April 5, 2011 Report Share Posted April 5, 2011 Hello, When I shift the gear to Reverse, my car makes loud noise and car shakes little bit. It also does it when I shift it from N to D, but less noise and movement. Transmission fluid was flushed 1 year ago. Stage 0 was done at the same time. Car has 147k miles. 1996 850R. I notice it more when car was parked on hills. Is this transmission mounts problem? If it is, how hard to replace them? Thank you. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted April 5, 2011 Report Share Posted April 5, 2011 Have any of the other mounts ever been replaced? Link to comment Share on other sites More sharing options...
FAST850R Posted April 5, 2011 Author Report Share Posted April 5, 2011 Have any of the other mounts ever been replaced? I replaced the front top, and the right bottom engine mounts. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted April 5, 2011 Report Share Posted April 5, 2011 Front and rear hydraulic mounts would be more suspect, usually revealing themselves in R with a loud bang. Link to comment Share on other sites More sharing options...
FAST850R Posted April 5, 2011 Author Report Share Posted April 5, 2011 Front and rear hydraulic mounts would be more suspect, usually revealing themselves in R with a loud bang. Are you talking about the transmission mount for the front? The rear mount is the one that really hard to replace, correct? Link to comment Share on other sites More sharing options...
the commissar! Posted April 5, 2011 Report Share Posted April 5, 2011 that is referring to A and G in this here pic... Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted April 5, 2011 Report Share Posted April 5, 2011 that is referring to A and G in this here pic... This. Don't buy the APA/URO versions of these mounts. Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted April 5, 2011 Report Share Posted April 5, 2011 This. Don't buy the APA/URO versions of these mounts. why not? useless? break easily? Link to comment Share on other sites More sharing options...
the commissar! Posted April 5, 2011 Report Share Posted April 5, 2011 why not? useless? break easily? longevity...certain things you only want to do when you must...if buying Volvo brand parts gets me 50% greater or more life and cost twice as much, it is still worth it for some things...this is one of them Link to comment Share on other sites More sharing options...
cn90 Posted April 5, 2011 Report Share Posted April 5, 2011 Just curious what is the procedure for checking all these engine/trans mounts? - I understand VISUAL inspection needs to be done but sometimes look can be deceving. 2. Any opinion re jacking up the engine a bit to see if the mount is bad? Or jack up the trans a bit? Link to comment Share on other sites More sharing options...
FAST850R Posted April 10, 2011 Author Report Share Posted April 10, 2011 Thank you for the replies. How long does it take to replace those two mounts? Do you guys have any tips on it before I tackle it? Link to comment Share on other sites More sharing options...
