Jack8745 Posted April 5, 2011 Report Share Posted April 5, 2011 i have the newer style oil pan with oil cooler built-in on the way to my house. Can someone please post a schematic from a manual of how the parts come together. does anyone know if both orange/red dipsticks work with this pan ? thanks jack Link to comment Share on other sites More sharing options...
Volvo5.0 Posted April 5, 2011 Report Share Posted April 5, 2011 i have the newer style oil pan with oil cooler built-in on the way to my house. Can someone please post a schematic from a manual of how the parts come together. does anyone know if both orange/red dipsticks work with this pan ? thanks jack Dipstick will work fine. You do need to change the metal coolant pipe on the rear of the engine.... Link to comment Share on other sites More sharing options...
lookforjoe Posted April 5, 2011 Report Share Posted April 5, 2011 reference thread And the oil pump pickup tube, 3 new seals, oil pressure feed line & new seals, and the flex line and hard line from the water dist pipe to the turbo water port as well as both oil cooler flex lines (which vary depending on what year water dist pipe you get)... Link to comment Share on other sites More sharing options...
Jack8745 Posted April 5, 2011 Author Report Share Posted April 5, 2011 reference thread And the oil pump pickup tube, 3 new seals, oil pressure feed line & new seals, and the flex line and hard line from the water dist pipe to the turbo water port as well as both oil cooler flex lines (which vary depending on what year water dist pipe you get)... this is what im getting from maciek can you clarify if i also need a different oil pick up tube? thanks jack Link to comment Share on other sites More sharing options...
lookforjoe Posted April 5, 2011 Report Share Posted April 5, 2011 Yes, you need the oil pickup tube. AND the oil cooler water return pipe that screws into the block. I also had to change the turbo oil feed line, it's shaped differently because of the oil cooler water pipes. Link to comment Share on other sites More sharing options...
