boxpin Posted April 30, 2011 Report Share Posted April 30, 2011 My 95 850 N/A will not let the Seatbelt go. It is wound up and you can pull it about an inch then it latches. Release and pull another inch then it latches. Over and over until you get enough out to buckle. Can this be fixed or must it be replaced? Link to comment Share on other sites More sharing options...
DAZV70R Posted April 30, 2011 Report Share Posted April 30, 2011 Hi There I recommend replacing as there are no user service parts inside ! There is a sticker on the one I bought from a wrecker that says "Warning do not remove or put in another vehicle" I'll leave that up to you ! there are two different types, with and without seat belt pretension, This is the version with the pretensioner fitted Took me about 40 mins to fit mine, the hardest being the lower seat belt bolt. I used a 12mm socket on a two foot long extension going in from under the front of the seat. The B pillar cover just pops off and behind you will find two 14 mm bolts and a torx screw. Hope this helps Regards Daz Link to comment Share on other sites More sharing options...
