vivalavolvo Posted May 3, 2011 Report Share Posted May 3, 2011 http://trionic.mobixs.eu/ Any one know where i can source a cable for this? Its not OBDII, but a special high speed two way serial connection. It requires a special converter. Link to comment Share on other sites More sharing options...
rkam Posted May 4, 2011 Report Share Posted May 4, 2011 K-line is normally two way serial connection on a single wire. K-line cable for Volvo can be standard KKL interface from ebay, but engine controller is normally connected to pin 3 and not 7. Some kind of adapter or rework of the interface is required. No ready made interface is available as far as I know. For Motronic 1.8 you might need one that is capable of 187500 bps. Blue transparent ones seems to work, black VOL-FCR might not. For Motronic 4.3 and 4.4 any interface should work. The speed is between 9600 and 12500 bps. For CAN bus you can use CANUSB from Lawicel. Link to comment Share on other sites More sharing options...
vivalavolvo Posted May 4, 2011 Author Report Share Posted May 4, 2011 KKL! that's the term i could not recall. As long as i can get the hardware needed i can modify it to fit. I was going to make my own conversion adapter but the intercooler that does all the work is really really hard to find, i pretty much have the other parts laying around. thanks! this is for 4.3 btw"KKL409.1 VAG-COM 409" This should work as long as i swap pin 7 to pin 4? I see no Volvo ones as you warned, they are sold as VW/Audi cables. Is this what i need? Link to comment Share on other sites More sharing options...
rkam Posted May 4, 2011 Report Share Posted May 4, 2011 Yes, they are normally sold with VAG-COM 409. Pin 7 to 3 for M4.3. I guess you hit the wrong key. Link to comment Share on other sites More sharing options...
vivalavolvo Posted May 4, 2011 Author Report Share Posted May 4, 2011 it seems like i did! There all over ebay, any i should look out for? Link to comment Share on other sites More sharing options...
