Dflo1121 Posted May 3, 2011 Report Share Posted May 3, 2011 Our 2000 S70 starts, runs for short time then completely shuts down. I don't suspect fuel pump because it does run for short time, but I may be wrong. Could it possibly be something to do with alternator or electronics side (computer/Chip)? Does anybody have any ideas before I bring it in to a Dealer/Mechanic? Thanks Link to comment Share on other sites More sharing options...
Chef JPD Posted May 3, 2011 Report Share Posted May 3, 2011 How long does it run before it shuts down? My C70 did this occasionally, started and died within 2 seconds. Turned out that it was the antennae ring for the Immobilizer that is around the ignition switch. This part----->Clicky Link to comment Share on other sites More sharing options...
Dflo1121 Posted May 3, 2011 Author Report Share Posted May 3, 2011 Thanks for the response. Is that easy to remove and replace? Are special tools required. The problem is that I'm currently overseas and I'm trying to help my son out. So I can't look at it to see what is needed. Thanks Link to comment Share on other sites More sharing options...
Chef JPD Posted May 3, 2011 Report Share Posted May 3, 2011 very easy to replace, you just need to remove the steering wheel "clamshell" cover (3 screws on the bottom) This exposes the ignition switch and the ring, just pop it out and plug in the new one. Link to comment Share on other sites More sharing options...
hi. my name is AJ Posted May 4, 2011 Report Share Posted May 4, 2011 I'm having the same issue. starting for a second, then engine immediately shuts down. Link to comment Share on other sites More sharing options...
Dflo1121 Posted May 4, 2011 Author Report Share Posted May 4, 2011 very easy to replace, you just need to remove the steering wheel "clamshell" cover (3 screws on the bottom) This exposes the ignition switch and the ring, just pop it out and plug in the new one. Wow! That sounds easy enough.Thanks for the help. I'll let you know how I made out. Link to comment Share on other sites More sharing options...
Chef JPD Posted May 4, 2011 Report Share Posted May 4, 2011 if this isn't the fix, check the fuel pump relay next. I replaced my FP relay first, no joy, then the immobilizer ring cured the problem. Link to comment Share on other sites More sharing options...
ozone_1974 Posted May 4, 2011 Report Share Posted May 4, 2011 had the same problem 2 or 3 years ago .. cleaned the immobilizer antenna connector and problem was fixed. Link to comment Share on other sites More sharing options...
