Malvasi Posted May 5, 2011 Report Share Posted May 5, 2011 Hey guys, I have searched and can't find a solid answer. Can you anyone tell me where the speed sense wire is on the 850's? Is it in the harness like the x70's? This is for my AVIC-D3 I have installed. Thanks! Link to comment Share on other sites More sharing options...
Oreo931 Posted May 5, 2011 Report Share Posted May 5, 2011 Hey guys, I have searched and can't find a solid answer. Can you anyone tell me where the speed sense wire is on the 850's? Is it in the harness like the x70's? This is for my AVIC-D3 I have installed. Thanks! I don't remember which wire off hand, but it one of the two wires on the plug of your ABS wheel sensor. It plugs in right in front of the strut on each front wheel. Link to comment Share on other sites More sharing options...
Malvasi Posted May 5, 2011 Author Report Share Posted May 5, 2011 Wow that seems pretty intense for a speed sense wire... There isn't anywhere to tap into it in the cab or engine bay? Link to comment Share on other sites More sharing options...
Oreo931 Posted May 5, 2011 Report Share Posted May 5, 2011 Wow that seems pretty intense for a speed sense wire... There isn't anywhere to tap into it in the cab or engine bay? Not that I know of. The wire goes right into the engine bay, so I don't see what the big deal is... Link to comment Share on other sites More sharing options...
Malvasi Posted May 5, 2011 Author Report Share Posted May 5, 2011 I guess you're right, any idea how to identify which is the correct wire? I don't feel like guessing which is which. Link to comment Share on other sites More sharing options...
Oreo931 Posted May 5, 2011 Report Share Posted May 5, 2011 I guess you're right, any idea how to identify which is the correct wire? I don't feel like guessing which is which. Nope. You've got a 50/50 shot. If it doesn't work the first time, just tap into the other wire instead. Again, not too much work. Or you can wait until someone responds to this thread who knows the correct color wire to tap into. Link to comment Share on other sites More sharing options...
bergmjs Posted May 5, 2011 Report Share Posted May 5, 2011 Isn't the speed sensor on '95- on the trans itself? Mine was. Link to comment Share on other sites More sharing options...
Malvasi Posted May 5, 2011 Author Report Share Posted May 5, 2011 Isn't the speed sensor on '95- on the trans itself? Mine was. Did you tap into the speed sensor? Which wire did you use? Link to comment Share on other sites More sharing options...
bergmjs Posted May 6, 2011 Report Share Posted May 6, 2011 Did you tap into the speed sensor? Which wire did you use? Well I replaced my auto trans with a manual trans out of a '98. So I had the speed sensor wires that were supposed to go to the speed sensor on the '95 trans and spliced them into the ABS signal off the front driver's side wheel. There were two wires coming off the speed sensor and two wires off the ABS sensor, so I spliced one wire from the speed signal into one ABS wire and the other into the other. I don't think polarity matters on it. Link to comment Share on other sites More sharing options...
Oreo931 Posted May 6, 2011 Report Share Posted May 6, 2011 I don't think polarity matters on it. Yes it does. Link to comment Share on other sites More sharing options...
bergmjs Posted May 6, 2011 Report Share Posted May 6, 2011 Yes it does. Maybe for his application but it didn't for the speedometer. It's just a pulse wave coming off the sensor, doesn't matter which way you look at it. Link to comment Share on other sites More sharing options...
Malvasi Posted May 8, 2011 Author Report Share Posted May 8, 2011 I have seen a few threads that were speaking of a tab on the back of the cluster can be used for VSS. Anyone know if this is true for the 850's? Link to comment Share on other sites More sharing options...
Oreo931 Posted May 8, 2011 Report Share Posted May 8, 2011 Maybe for his application but it didn't for the speedometer. It's just a pulse wave coming off the sensor, doesn't matter which way you look at it. It mattered for my speedo. Link to comment Share on other sites More sharing options...
