WayAway Posted May 12, 2011 Report Share Posted May 12, 2011 Im looking for some advice on a flywheel job in a 99 lpt. The starter chewed the crap out of the flywheel. I know I have to pull the motor. Never done this before. Thanks Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 12, 2011 Report Share Posted May 12, 2011 Are you asking for tips on engine removal? FWD? Link to comment Share on other sites More sharing options...
WayAway Posted May 12, 2011 Author Report Share Posted May 12, 2011 Basically yes. It's awd. I've never pulled a motor in a fwd car. I'm really well rounded with working on anything that needs to be fix on a car. I'm looking for maybe a time frame I'm up against. I'm sure it's straight forward, but I just want to know the ups and downs before I go at it. Link to comment Share on other sites More sharing options...
Keaton85 Posted May 12, 2011 Report Share Posted May 12, 2011 about 3 days if you take your time and this is the first time you have done it. If the AWD is connected then thats a little bit of a pain. You can either remove the bevel gear in the car or take the motor/tranny out with the bevel gear attatched. Although the flange to the propeller shaft can get in the way. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted May 13, 2011 Report Share Posted May 13, 2011 if its needed its a good time to do all the other stuff while its out..timing belt..turbo coolant hoses..etc..its all SOO easy while engine is out... Link to comment Share on other sites More sharing options...
Keaton85 Posted May 13, 2011 Report Share Posted May 13, 2011 Possibly a clutch depending on miles, rms and so forth.. Link to comment Share on other sites More sharing options...
