rbodor3 Posted May 12, 2011 Report Share Posted May 12, 2011 Pulled the WG actuator vac line and boost was good. With the actuator on it was only hitting 4-5 psi. I kept adjusting the actuator until the nut was all the way tight - boost onset is really early but still dumps at 5psi. Spikes a bit at the shifts. I'm thinking bad TCV? It's an ipd one. <_< Link to comment Share on other sites More sharing options...
rbodor3 Posted May 13, 2011 Author Report Share Posted May 13, 2011 maybe bad WG? Link to comment Share on other sites More sharing options...
98t5M Posted May 13, 2011 Report Share Posted May 13, 2011 Pulled the WG actuator vac line and boost was good. With the actuator on it was only hitting 4-5 psi. I kept adjusting the actuator until the nut was all the way tight - boost onset is really early but still dumps at 5psi. Spikes a bit at the shifts. I'm thinking bad TCV? It's an ipd one. <_< Sounds like your tcv to me. Could be your ecu though. Try pulling the ecu out for 10 minutes then replacing it and see if it fixes it. You may be stuck in limp mode.If boost was okay when you pulled the vac line that means the WG is not the problem. Link to comment Share on other sites More sharing options...
TRACStar Posted May 13, 2011 Report Share Posted May 13, 2011 You may be stuck in limp mode. If boost was okay when you pulled the vac line that means the WG is not the problem. What he said Link to comment Share on other sites More sharing options...
rbodor3 Posted May 13, 2011 Author Report Share Posted May 13, 2011 putting back in the stock TCV; however the colored markings are gone. Anybody have a diagram showing which TCV port is the WG, CBV, etc.??? Link to comment Share on other sites More sharing options...
rbodor3 Posted May 13, 2011 Author Report Share Posted May 13, 2011 It was the TCV. Replaced with stock and performance boost is back. Link to comment Share on other sites More sharing options...
NJGreenBudd Posted May 14, 2011 Report Share Posted May 14, 2011 i had the same thing happen with the ipd one after 60,000 miles of use, back to a new stock one and it's great. good to hear you got it fixed though. Link to comment Share on other sites More sharing options...
rbodor3 Posted May 14, 2011 Author Report Share Posted May 14, 2011 yes, I've put about 45k on the IPD one. I will be buying a new IPD one, because the response time is so much faster. The response time for the stocker is too slow and boost is much more erratic; which makes me nervous. :monkey: Link to comment Share on other sites More sharing options...
98t5M Posted May 15, 2011 Report Share Posted May 15, 2011 yes, I've put about 45k on the IPD one. I will be buying a new IPD one, because the response time is so much faster. The response time for the stocker is too slow and boost is much more erratic; which makes me nervous. Have you asked them about replacing it under warranty? Link to comment Share on other sites More sharing options...
rbodor3 Posted May 15, 2011 Author Report Share Posted May 15, 2011 I thought they only had a 1 year wrranty? Link to comment Share on other sites More sharing options...
rbodor3 Posted May 24, 2011 Author Report Share Posted May 24, 2011 blew through another TCV actuator today. :angry: Link to comment Share on other sites More sharing options...
T5wagon1717 Posted May 26, 2011 Report Share Posted May 26, 2011 I'd ask. Ipd has a pretty good customer Service rep Link to comment Share on other sites More sharing options...
