PyROTech Posted May 13, 2011 Report Share Posted May 13, 2011 ok, I need to have internet access to plug a streaming desktop tv service into... Its a box that has all the settings preconfigured and you just plug into a router with internet access and it works. The place im going to be using it doesnt have phone line or cable access. Problem -the box only connects via rj45 connection. Data sticks are cheap enough for me to just use that for net access, but i need a router for the connection. AND its $400 for the wireless/router!!!! I only need the service for 3 weeks and $400 is way to much for that small amount of time. Suggestions? I found this: data stick plugs into it, except im worried without external antenna ill have shitty reception http://www.option.co...and-routers/x1/ edited part: with the help of google, and getting over my lazyness i found my answer (hopefully) http://www.mofinetwork.com/index.php?option=com_content&view=article&id=48&Itemid=60 $100 & rogers data stick $150 & $65 data plan total: $315 for the one month Link to comment Share on other sites More sharing options...
Boost3237 Posted May 13, 2011 Report Share Posted May 13, 2011 Do you have a wireless router already? If so go buy another wireless router and use it as a client repeater. You wont be able to stream HD over wifi very well though. Link to comment Share on other sites More sharing options...
PyROTech Posted May 13, 2011 Author Report Share Posted May 13, 2011 Got the router listed above and grabbed the usb data stick. will be home later to see if it works with the streaming box before I go and see if has reception at the location. edited part: testing now the speed of stick, im sure ill be watching full HD over this blazing fast data stick. Link to comment Share on other sites More sharing options...
