Organs016 Posted May 22, 2011 Report Share Posted May 22, 2011 Hey guys I just had my car power washed. I ran out of gas so I couldn't drive it . I filled up with a gallon of gas and put it in my car but it just cranks and it doesn't start. Can someone help me out. Is it a trick or procudure to get it started after I ran out of gas? Thanks. Link to comment Share on other sites More sharing options...
Keaton85 Posted May 22, 2011 Report Share Posted May 22, 2011 Yeah umm dont run out of gas!! Unless you have 1k+ to replace the pump. Anyway FILL the tank. A gallon isnt going to do anything since the tank has two pick-ups, one on each side of the diff. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 23, 2011 Report Share Posted May 23, 2011 A gallon of fuel will ABSOLUTELY start the vehicle. Did the no start condition occur before or after the power wash? Was it out of gas when it was power washed? Link to comment Share on other sites More sharing options...
Keaton85 Posted May 23, 2011 Report Share Posted May 23, 2011 A gallon of fuel will ABSOLUTELY start the vehicle. Did the no start condition occur before or after the power wash? Was it out of gas when it was power washed? Even with the split tank? as this has two separate areas for fuel. So if it only slightly fills one and the other is empty I would suspect that that it would suck air.. Link to comment Share on other sites More sharing options...
Organs016 Posted May 23, 2011 Author Report Share Posted May 23, 2011 how should i fix this problem. I have a quarter of a tank on the six do I need to add more gas. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 23, 2011 Report Share Posted May 23, 2011 Even with the split tank? as this has two separate areas for fuel. So if it only slightly fills one and the other is empty I would suspect that that it would suck air.. Yes. how should i fix this problem. I have a quarter of a tank on the six do I need to add more gas. Did your friend pressure wash the engine bay? Link to comment Share on other sites More sharing options...
