Matts 850 GLT Posted May 23, 2011 Report Share Posted May 23, 2011 Hi Trying to find a vacuum leak, all hoses replaced, PCV system, elbows etc. When I try to pull vaccumm from the hose that goes from the inlet manifold to the compressor bypass valve there is no vacuum. It doesn't hold anything either way as I can blow through it. Has it failed? What are the options? Dealer can't supply the diaghram as the turbo isn't made by Volvo but Mitsubishi. Would a Mitsubishi dealer be able to help? I am not going down the blow off route as the car is auto. Thanks Matt Ancient 94 turbo auto Link to comment Share on other sites More sharing options...
jschaefer7406 Posted May 23, 2011 Report Share Posted May 23, 2011 Matt, As you suspected, the diaphragm should hold both vacuum and pressure. Sounds like it's shot ... Actually though, the valve IS available from Volvo, but is VERY expensive (over $150 last I checked). Here is a link to a Genuine Mitsubishi replacement, with the diaphragm being the updated orange rubber: http://cgi.ebay.com/ebaymotors/Turbo-BOV-Bypass-Repair-Kit-VOLVO-TD04HL-15G-16T-19T-_W0QQcmdZViewItemQQhashZitem2310441823QQitemZ150596753443QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Other companies have them available (ipd, EST, etc), but this one is cheaper and of better quality. I've personally used it and you won't be disappointed . Hope this helps, Joe Link to comment Share on other sites More sharing options...
--Aaron-- Posted May 25, 2011 Report Share Posted May 25, 2011 I have a very young, mint diaphram if you're in need...... Link to comment Share on other sites More sharing options...
