Dick Dastardly Posted June 9, 2011 Report Share Posted June 9, 2011 I don't think we will see Dave there... I figured not...not his "style" but thought I'd ask. Round 2 of questions - Kevin works until noon and is curious what will be happening and if he will still be able to make it leaving Sayre, PA at noonish. I know last year we went for a spirited drive to "T" something park but didn't recall a time That would be Treman park.. Rt 327...i used to terrorize that road for years.. Link to comment Share on other sites More sharing options...
sconeman Posted June 9, 2011 Report Share Posted June 9, 2011 I figured not...not his "style" but thought I'd ask. That would be Treman park.. Rt 327...i used to terrorize that road for years.. unless I figure out my "new problem" with the 850 I won't be taking a "spirited drive" anywhere. I'm hoping it's as simple as a leaking fuel filter. smells like gas around that area and car is slow as sh** all of a sudden. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted June 9, 2011 Report Share Posted June 9, 2011 unless I figure out my "new problem" with the 850 I won't be taking a "spirited drive" anywhere. I'm hoping it's as simple as a leaking fuel filter. smells like gas around that area and car is slow as sh** all of a sudden. Any pressure drop? Link to comment Share on other sites More sharing options...
sconeman Posted June 9, 2011 Report Share Posted June 9, 2011 Any pressure drop? don't know yet. I'm going to buy myself a fuel pressure gauge tomorrow. I need one. Link to comment Share on other sites More sharing options...
Keep Calm Chive On Posted June 9, 2011 Report Share Posted June 9, 2011 Yes that road to Truman... glorious. Luckily I figured out what was happening with my car. Hit the lovely connector ramp for the 2 Elmira exists and baaaaaaaa PA PA APA PAA PAA misfire cylinder 1. Cleared the codes and was driving along at like 4k again ba ba bapapoapsofpaopoapof. So I replaced the cap & rotor because the plugs were 1 week old the wires checked out legit and the rotor was spanked (only 3 years old)and the cap had some build up. being in a rush to get home and back and the lack of paying attention in the dark with a flash light tonight I managed to loop cylinder 5 wire under the Crank position sensor. So I was like aight we good to go... until that was I put load on the car and ba ba ba stallsy almost. So I was heated and long story short I routed the Crank Position sensor under the heater hose so that the extra wire wouldnt loop upward then I rotated all cap/rotor leads of the spark plug wires to about 2-3 oclock. Started her up, hopped on the owego exit WOT and boom straight to 125 glorious. Just to double check I pulled a U'y at lounsbery and hit that on ramp too... Good to go. Link to comment Share on other sites More sharing options...
MrVolvo75 Posted June 9, 2011 Author Report Share Posted June 9, 2011 So I am not the only one with problems...right now I am driving a NA with a lot of expensive turbo equipment on it. Won't boost, gauge says peak is 6 psi, but that just means it is not boosting really. New Bosch MAF in February, complete tune-up/service last month- no boost since. Checked all the pipes, no evidence of leaks, IPD TCV is hooked up right...car runs fine, just its not a turbo. So spirited drive will be a slow one- I am counting on your guys to figure it out. Oh, btw, no CEL. Would the car be "storing codes" if there is no light? Such a bummer it keeps me up at night! Link to comment Share on other sites More sharing options...
Keep Calm Chive On Posted June 9, 2011 Report Share Posted June 9, 2011 what you got for intercooler hommie? I had the exact same thing and one of the bellows of the intercooler had a crack in it. no-low boost would allow the crack to remain closed causing no issues. Anything over 5-6 psi would force the crack apart and bye bye boost Link to comment Share on other sites More sharing options...
lookforjoe Posted June 10, 2011 Report Share Posted June 10, 2011 So I am not the only one with problems...right now I am driving a NA with a lot of expensive turbo equipment on it. Won't boost, gauge says peak is 6 psi, but that just means it is not boosting really. New Bosch MAF in February, complete tune-up/service last month- no boost since. Checked all the pipes, no evidence of leaks, IPD TCV is hooked up right...car runs fine, just its not a turbo. So spirited drive will be a slow one- I am counting on your guys to figure it out. Oh, btw, no CEL. Would the car be "storing codes" if there is no light? Such a bummer it keeps me up at night! How many miles on the motor? You could have a clogged cat. You can loosen the DP & drive - you'll know immediately if that's it. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted June 10, 2011 Report Share Posted June 10, 2011 Will beer be made available to us on Sat? Link to comment Share on other sites More sharing options...
MrVolvo75 Posted June 10, 2011 Author Report Share Posted June 10, 2011 Hussein, only 148K...Ipd exhaust sittin in a box, maybe we make it a big project day!! Scum, i like beer : ) Link to comment Share on other sites More sharing options...
Keep Calm Chive On Posted June 10, 2011 Report Share Posted June 10, 2011 lets make it hack out the cat day... because its new york and emissions are overrated anyways Link to comment Share on other sites More sharing options...
sconeman Posted June 10, 2011 Report Share Posted June 10, 2011 yeah let's do that to my car. oh wait I don't have one Link to comment Share on other sites More sharing options...
Keep Calm Chive On Posted June 10, 2011 Report Share Posted June 10, 2011 OMG Samesies!!! welp kristain I was gunna say bring a intake pipe for your boy kurtis buttttt instead I will be investing "your intake money" in a new tire that after a short 3 weeks... has already been plugged once then some kinda blow out today... looks like steel wire got the best of me Hooray for tractor trailers not having to clean up their mess the good news... I start vacation today at noon-oclock, I will be sober starting roughly next next monday Link to comment Share on other sites More sharing options...
Keep Calm Chive On Posted June 10, 2011 Report Share Posted June 10, 2011 marky mark & the funky boys (just mark no funky boys) said they are coming!!!... Link to comment Share on other sites More sharing options...
ozzimark Posted June 10, 2011 Report Share Posted June 10, 2011 marky mark & the funky boys (just mark no funky boys) said they are coming!!!... For a limited time only! Got somewhere to be at 3, and the meet is about 1:45 from my house. Maybe I can push my departure off until 2 and be a little late for my 2nd event of the day Might bring this girl along if the meetup area is suitable for dogs. Link to comment Share on other sites More sharing options...
