atefitty Posted May 28, 2011 Report Share Posted May 28, 2011 I'm replacing my 1997 850 door lock actuator and I can't seem to figure out the procedure to get the lock cylinder back into the actuator..Basically how the heck do you put it all back together..If anyone has a link or can explain the procedure that would be a great help. Link to comment Share on other sites More sharing options...
Gilhuly Posted May 28, 2011 Report Share Posted May 28, 2011 Here you go. This is a screen print from VADIS. There is an illustration not included which shows how to detach the handle with the 3 torx bolts on the door edge. two are under a cover that must be pried off.Doorlockcyl.doc Link to comment Share on other sites More sharing options...
atefitty Posted May 29, 2011 Author Report Share Posted May 29, 2011 Here you go. This is a screen print from VADIS. There is an illustration not included which shows how to detach the handle with the 3 torx bolts on the door edge. two are under a cover that must be pried off. Wow, I really appreciate that..I must of spent 2 hours trying to do this simple procedure. I think messed up my door lock handle trying to pry off the trim part around the key cylinder..I may pick up another one from the junk yard if I can just switch it out. Link to comment Share on other sites More sharing options...
