Prezman26 Posted May 30, 2011 Report Share Posted May 30, 2011 So I just downgraded from my two 12" subs to one 12" sub and everything was going fine. I put on a song where the bass hits pretty hard, turned up the volume and at a certain volume level, the bass hit and the whole stereo cut out. I turned it off then turned it on and had to put the volume setting down one and everything worked fine. But everytime it hits the one level it cuts out. All connections in the back are fine. This never happened with the two 12"s. Do i need to add something to the set-up? I will say that all my speakers and sub are routed into the 1000w amp. Link to comment Share on other sites More sharing options...
Prezman26 Posted May 30, 2011 Author Report Share Posted May 30, 2011 Anybody? Link to comment Share on other sites More sharing options...
--Aaron-- Posted May 30, 2011 Report Share Posted May 30, 2011 Sounds like there's a problem with the wiring as far as resistance levels go. Link to the sub you're using so I can see how many voice coils and how many ohms per coil? Also, link to your amp's specs? How is the sub wired to the amp, bridged, etc? Link to comment Share on other sites More sharing options...
Chilled man Posted May 30, 2011 Report Share Posted May 30, 2011 Sounds like there's a problem with the wiring as far as resistance levels go. Link to the sub you're using so I can see how many voice coils and how many ohms per coil? Also, link to your amp's specs? How is the sub wired to the amp, bridged, etc? Agreed sounds like the amp is cutting out due to overheating. Link to comment Share on other sites More sharing options...
Prezman26 Posted May 31, 2011 Author Report Share Posted May 31, 2011 Thanks Aaron and Justin. I'll tell Steve when I head down to his shop tomorrow. Link to comment Share on other sites More sharing options...
Ghost Shadow Posted May 31, 2011 Report Share Posted May 31, 2011 mike, honestly......you are coming down tomorrow to my shop. i ignored 4 texts about it and two PM's and this thread. WTF relax, what ever you do to calm down. this is a simple problem i can look at when you get here. OMG edit: you see my avatar...that shocker is for you, two in the pink one in the stink Link to comment Share on other sites More sharing options...
Ghost Shadow Posted May 31, 2011 Report Share Posted May 31, 2011 Mike, there is $12,500 of equipment in this car TWO JL 1000/1v2 TWO JL 12w7 One JL HD600/4 ONE Hight Output 210 AMP Alternator ONE Kenetic 1400cca battery in the front ONE Kinetic 2400 CCA battery in the rear Two Cases of soundening One Audio control epic center One MTX REQ5 One Set of Touch Screen DVD headrest monitors Two Sets Kenwood Excelon XR17s Speakers Thats just the Audio and Video side, not taking cosmetics, wheels lighting and go fast parts Now he doesnt complain about it shutting on and off when the bass hits. If i can get this shit to work with the OEM navigation system...Your car is cake...chill...i gots you. Link to comment Share on other sites More sharing options...
Prezman26 Posted May 31, 2011 Author Report Share Posted May 31, 2011 lol I get worried easily.....it's from hanging around Aaron so much JK aaron, your the man. Link to comment Share on other sites More sharing options...
--Aaron-- Posted June 1, 2011 Report Share Posted June 1, 2011 lolwat Mike, from now on..........when you buy a used subwoofer make sure you know how many voice coils it has, if 2 then you need to be aware of how they're wired inside the box. Also be aware of your amp's capabilities. :P Link to comment Share on other sites More sharing options...
