thewhiteguy1 Posted June 1, 2011 Report Share Posted June 1, 2011 Okay, so i have the d2 racings set and i want to go lower in the rear. who makes shorter 5" to 2.5" springs?? Link to comment Share on other sites More sharing options...
The Big Tuna Posted June 1, 2011 Report Share Posted June 1, 2011 Get some blown Nivomats, that Sh*t will drop it like it's hot hahah Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted June 2, 2011 Author Report Share Posted June 2, 2011 so no real answers??? Link to comment Share on other sites More sharing options...
The Big Tuna Posted June 2, 2011 Report Share Posted June 2, 2011 Wow nobody got humor today, pm Kalvin and see what set up he is running in the rear, his car is very low and he is running d2's in the front as well Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted June 2, 2011 Author Report Share Posted June 2, 2011 Wow nobody got humor today, pm Kalvin and see what set up he is running in the rear, his car is very low and he is running d2's in the front as well i plus oned you i thought it was funny Link to comment Share on other sites More sharing options...
Vagabond Posted June 2, 2011 Report Share Posted June 2, 2011 Here's a link for what I've been browsing for custom spring sizes. http://www.speedwaymotors.com/Race-Shock-Coil-Over.html?first_answer=1 Link to comment Share on other sites More sharing options...
Dan A Posted June 2, 2011 Report Share Posted June 2, 2011 http://www.buyimportperformance.com/category_s/1526.htm Link to comment Share on other sites More sharing options...
JVC Posted June 2, 2011 Report Share Posted June 2, 2011 did you already pull the adjusters too? Link to comment Share on other sites More sharing options...
kalvin Posted June 2, 2011 Report Share Posted June 2, 2011 did you already pull the adjusters too? That's what I did. Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted June 2, 2011 Author Report Share Posted June 2, 2011 did you already pull the adjusters too? that's the next step, the adjusters are all the way down already.. Link to comment Share on other sites More sharing options...
TurboBrick44 Posted June 7, 2011 Report Share Posted June 7, 2011 I just took the adjusters out in the back as well and im happy with it. Kalvin how low are you in the front? Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted June 7, 2011 Author Report Share Posted June 7, 2011 doesn't kalvin have shorter springs in the front?? Link to comment Share on other sites More sharing options...
TurboBrick44 Posted June 8, 2011 Report Share Posted June 8, 2011 doesn't kalvin have shorter springs in the front?? He must cause his looks lower than mine. I just got these coilovers and im about 1/2 inch from maxed out in the front. The only way to go lower is to get shorter springs otherwise the bottom of your coilovers will be hitting your axles. I removed my adjusters in the back and made new brackets to hold the springs in because the OEM ones wont work. I can post pics of my wheel gap if your interested in doing this assuming you havn't already. Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted June 8, 2011 Author Report Share Posted June 8, 2011 He must cause his looks lower than mine. I just got these coilovers and im about 1/2 inch from maxed out in the front. The only way to go lower is to get shorter springs otherwise the bottom of your coilovers will be hitting your axles. I removed my adjusters in the back and made new brackets to hold the springs in because the OEM ones wont work. I can post pics of my wheel gap if your interested in doing this assuming you havn't already. how/where did you get the custom brackets to hold them? right now i still have the perches on in the back with the adjuster collars spun all the way down.. Link to comment Share on other sites More sharing options...
TurboBrick44 Posted June 8, 2011 Report Share Posted June 8, 2011 I took some a piece of steel metal and cut it into a rectangle. The length was somewhere around 4 inches and the width was around 3 inches. I drilled a hole in the center and placed it at the bottom of the spring and bolted it in. I used a lock washer and some locktite as well to make sure its secure. You can get the metal from a hardware store. Link to comment Share on other sites More sharing options...
