Yukon Posted June 6, 2011 Report Share Posted June 6, 2011 Trying to get radio code for HU-615 radio for my Volvo 40. Serial Number is VO345020315461. Vin YV1VS27583F977671. My email is jwarfi@yahoo.com. Thanks Link to comment Share on other sites More sharing options...
boxpin Posted June 6, 2011 Report Share Posted June 6, 2011 I dont think anyone has the generator for this. You would need to contact a dealer. Just tell them you replaced your battery and it says code. If they dont give it to you over the phone call another dealer. Link to comment Share on other sites More sharing options...
VolvoGuy500 Posted June 10, 2011 Report Share Posted June 10, 2011 I dont think anyone has the generator for this. You would need to contact a dealer. Just tell them you replaced your battery and it says code. If they dont give it to you over the phone call another dealer. This. What interests me is I wonder how the codes are generated in the first place. It'd be interesting to see if there's any specific pattern between the serial numbers and matching unlock codes, or if they're just random 4 digit numbers. There has to be repeat codes anyhow, because 4 digits only give you 10K combos, and there are quite a lot more than 10K Volvo HU's floating around out there. Link to comment Share on other sites More sharing options...
Dan A Posted June 10, 2011 Report Share Posted June 10, 2011 <br />This.<br /><br />What interests me is I wonder how the codes are generated in the first place. It'd be interesting to see if there's any specific pattern between the serial numbers and matching unlock codes, or if they're just random 4 digit number. Not likely straightforward. Probably some random math algorythm. Link to comment Share on other sites More sharing options...
Guest Terrance Posted July 18, 2011 Report Share Posted July 18, 2011 So does this mean nobody has the numbers cause if any one do post them on here Link to comment Share on other sites More sharing options...
TRACStar Posted July 19, 2011 Report Share Posted July 19, 2011 because 4 digits only give you 10K combos FAIL I thought you were at least smart with numbers, there is only 1296 possibilites. ;) Link to comment Share on other sites More sharing options...
trs80 Posted July 19, 2011 Report Share Posted July 19, 2011 FAIL I thought you were at least smart with numbers, there is only 1296 possibilites. 0000 through 9999 would give you 10k possible 4 digit codes. I doubt Volvo used "0000" as a code but the math still holds true. Link for those that require additional explanation, My link. To the OP: You will have to contact a dealer. You are only allowed three attempts before it is "OFF." Then you must wait two hours, with power to the unit, before you can attempt again.Forgot to add, Volvo only used 1-6 so yes 1296 would be correct. Link to comment Share on other sites More sharing options...
TRACStar Posted July 19, 2011 Report Share Posted July 19, 2011 Forgot to add, Volvo only used 1-6 so yes 1296 would be correct. Thank you, come again. ;) Link to comment Share on other sites More sharing options...
joerickson Posted July 22, 2011 Report Share Posted July 22, 2011 I had the same problem with my car, just pull the radio to see if the code is there like it was on mine. Link to comment Share on other sites More sharing options...
PyROTech Posted July 22, 2011 Report Share Posted July 22, 2011 most dealers will give you the code free of charge, as said above. This a sticky somewhere or no? b/c it seems a very common question. Link to comment Share on other sites More sharing options...
TRACStar Posted July 22, 2011 Report Share Posted July 22, 2011 I had the same problem with my car, just pull the radio to see if the code is there like it was on mine. Mine was written inside the front cover of the maintainance record book. And on a card that said radio security code inside the sleeve that holds all the literature. Link to comment Share on other sites More sharing options...
paulbonard Posted August 14, 2011 Report Share Posted August 14, 2011 Changed my battery, dont have a PIN written anywhere.... what info is needed? I have a 2002 Volvo S40 and the VIN is YV1VS29582F852102... any help would be appreciated. Link to comment Share on other sites More sharing options...
The Big Tuna Posted August 14, 2011 Report Share Posted August 14, 2011 Changed my battery, dont have a PIN written anywhere.... what info is needed? I have a 2002 Volvo S40 and the VIN is YV1VS29582F852102... any help would be appreciated. Read the pinned topic above!!! Link to comment Share on other sites More sharing options...
Dan A Posted August 22, 2011 Report Share Posted August 22, 2011 Hand delivery.... Link to comment Share on other sites More sharing options...
