Simota Catch Can
Kit Vexed
oh that's not like super small, i didnt want this huge thing in my engine bay.. plus the window is nice to have. the other cans i saw didnt have that. im not pushing as much boost as gilbert (18t/18-19psi) so im hoping the pressure wont be an issue with the smaller ports for me..
  • Replies 33
man those are some beefy lines, geez! you'd think those were hydraulic lines to a bulldozer lol. hey man, thanks a lot. you must be pushing some serious boost for that setup.. thanks a lot for the pics. seeing that is making me wonder if i should just pull the intake off and use the supplied line from the breather box directly instead of tapping into it down the road. either way, i appreciate the heck out of the help/direction on this. so on this particular can, the breather box line is going into the angled/upward nozzle, and the top/perpendicular nozzle is going into the PTC.. good?
The breather lines you use need to be the same or larger than stock, so 12 or 14mm ID, not OD. If you use small hose, you will likely cause CC pressure restrictions.
where do you get lines for the catch can? i quickly realized the provided line does not fit over the breather line, or onto the ptc nozzle.. i need larger! as Zappo said even with larger lines, the nozzle size stays the same - the inner diameter is still small; the outer wall/thickness of the nozzle is what increases..
