boxpin Posted June 16, 2011 Report Share Posted June 16, 2011 I am doing my manual swap and am inside the trans. The shift position arm has some wear and I am concern. Will this be an issue? Link to comment Share on other sites More sharing options...
matt b Posted June 16, 2011 Report Share Posted June 16, 2011 I haven't opened one, so I can't speak much. Contact Johann or look at his threads, he's opened up an M56 or three before. Out of curiosity, why open it ? We can't buy parts for these, the only hope is to source a junk one with another problem. Link to comment Share on other sites More sharing options...
boxpin Posted June 16, 2011 Author Report Share Posted June 16, 2011 Quaife Link to comment Share on other sites More sharing options...
lookforjoe Posted June 16, 2011 Report Share Posted June 16, 2011 Quaife Nice! If you're referring to the slight wear on the brass, I wouldn't worry about it. It's the tips of the forks, esp if it has the plastic tips that actually ride in the synchro hubs - I believe that's the area of concern. As long as those & the synchro cones are intact, I would expect you are good to go. Link to comment Share on other sites More sharing options...
boxpin Posted June 16, 2011 Author Report Share Posted June 16, 2011 Ok, thanks. I have not seen the quaife yet. It got delivered to my work and a coworker is bringing over tonight. I see the speed sensor ring on the OEM diff, is the quaife going to have the ring or will I need to pull it? Link to comment Share on other sites More sharing options...
bum2kev Posted June 16, 2011 Report Share Posted June 16, 2011 no need to take anything out to install the quaife... the diff comes right out when you unbolt it. Link to comment Share on other sites More sharing options...
boxpin Posted June 16, 2011 Author Report Share Posted June 16, 2011 Nice, now you tell me. I have been reading all these write ups and they all pull the clusters...so I followed blindly. I can see it now. I am replacing the bearings too. The bearing race, how do you get it out? I read that you can weld a bead around it and when it cools it comes out. Anyone try this? Link to comment Share on other sites More sharing options...
boxpin Posted June 16, 2011 Author Report Share Posted June 16, 2011 ok, got the races out. It was easy. Now I am stuck on this pivot pin. It wont budge. thoughts? Link to comment Share on other sites More sharing options...
Zappo Posted June 16, 2011 Report Share Posted June 16, 2011 no need to take anything out to install the quaife... the diff comes right out when you unbolt it. Yeah, that is how I did mine also. Install went fairly quickly. Now I am stuck on this pivot pin. It wont budge. thoughts? If you are replacing it, just keep working at it. Clamp down with some vice grips and pry with a screw driver. It will come out. Maybe hit it with some penetrating oil. Link to comment Share on other sites More sharing options...
boxpin Posted June 16, 2011 Author Report Share Posted June 16, 2011 ok, got that out but the new one is shorter. The fork did not have the plastic piece on it when I pulled the trans from the donor car....does the plastic spacer make up the difference? Link to comment Share on other sites More sharing options...
lengendsecko87 Posted June 16, 2011 Report Share Posted June 16, 2011 I think they're a huge difference. let me see if I can find that youtube video.. Link to comment Share on other sites More sharing options...
boxpin Posted June 16, 2011 Author Report Share Posted June 16, 2011 I guess I just need to make there there is some good throw there when I am done. Having a blast... Link to comment Share on other sites More sharing options...
boxpin Posted June 16, 2011 Author Report Share Posted June 16, 2011 Pedals are in Had to cut off and weld on the stop plate for the clutch pedal. I used my existing frame and swapped pedal arms. Is there supposed to be some sort of rubber stop so when the pedal is at rest against the stop plate it is not metal to metal? Link to comment Share on other sites More sharing options...
Zappo Posted June 16, 2011 Report Share Posted June 16, 2011 ok, got that out but the new one is shorter. The fork did not have the plastic piece on it when I pulled the trans from the donor car....does the plastic spacer make up the difference? You can space it with a washer to match. It seems that Volvo didn't come out with the plastic clip until 97, so you don't have to have it. Link to comment Share on other sites More sharing options...
bergmjs Posted June 16, 2011 Report Share Posted June 16, 2011 Why replace the fork pivot ball? It's just a steel ball, it won't go bad. Polish it and grease it, then you know you have the ball. Link to comment Share on other sites More sharing options...
