boosted_brick Posted June 19, 2011 Report Share Posted June 19, 2011 i bought this 850 wagon and the dude said he replaced the shocks in the back last year but the way the car sits i'm not sure i believe him anymore. i have a few boxes in the back so i know that'll effect the way it sits but i just find it a lil hard to believe the amount of weight i have back there is going to push it that low. any help would be great. Link to comment Share on other sites More sharing options...
prasamin Posted June 19, 2011 Report Share Posted June 19, 2011 what springs are on it? Link to comment Share on other sites More sharing options...
boosted_brick Posted June 19, 2011 Author Report Share Posted June 19, 2011 i honestly dont know. i guess i could get a flashlight and look :rolleyes: Link to comment Share on other sites More sharing options...
bergmjs Posted June 19, 2011 Report Share Posted June 19, 2011 The dampers don't affect the ride height. The only ones that do are the Bilstein TC's and only in the front because the spring perch is an inch higher. But in general dampers/shocks don't affect ride height at all, only the springs do. Link to comment Share on other sites More sharing options...
TRACStar Posted June 19, 2011 Report Share Posted June 19, 2011 The dampers don't affect the ride height. The only ones that do are the Bilstein TC's and only in the front because the spring perch is an inch higher. But in general dampers/shocks don't affect ride height at all, only the springs do. +1 The springs, if they're still stock, are probably just weaker than they were 15+ years ago. Link to comment Share on other sites More sharing options...
Speedbump Posted June 19, 2011 Report Share Posted June 19, 2011 Yep. If you took the shocks out and the car would sit just as high. The springs do the ride height work. Step off your back bumper car should go up/down twice. 2.5x tops Shocks are not shy about showing their age. If you are comfortable with it you need to get under the car. It's easy to tell if they are "a year old". But that's not why people are leaving bulletins to a lowrider contest under your wipers. Jack the car up at the proper lift points (lift the body up, not axle) and check the coil springs and see if they are broken. Pay special attention to where the spring just exits the cups they sit in, as below, right. (honda) Link to comment Share on other sites More sharing options...
bergmjs Posted June 19, 2011 Report Share Posted June 19, 2011 Wow, how'd you snap a coil off? My money is on the PO hauling a lot of crap around and the springs are just fatigued as hell. Steel does have an infinite life fatigue limit, but likely the springs are made to be close to that anyways and that only assumes a perfectly homogeneous material with no imperfections--which is obviously an overstatement. Link to comment Share on other sites More sharing options...
boosted_brick Posted June 20, 2011 Author Report Share Posted June 20, 2011 i took everything out today and it still sits that low. maybe the springs are just worn out. Link to comment Share on other sites More sharing options...
midlman Posted June 20, 2011 Report Share Posted June 20, 2011 Some of the wagons have the self leveling Nivomats. The shocks actually do level the ride by "pumping up" as you drive. If someone was cheap and replaced the nivomats (super expensive..like $400 each) with standard shocks, the car would sag as the springs are weaker due to some of the load being taken by the nivomats. Not sure how to tell the nivomat springs from the non-nivomats springs thoughThinking more about this...I've seen cars with blown nivomat shocks sit just like that....if that's the case (or he swapped in standard shocks)..your best bet is to get a set of aftermarket springs with regular shocks as the price of new nivomats is high... Some of the wagons have the self leveling Nivomats. The shocks actually do level the ride by "pumping up" as you drive. If someone was cheap and replaced the nivomats (super expensive..like $400 each) with standard shocks, the car would sag as the springs are weaker due to some of the load being taken by the nivomats. Not sure how to tell the nivomat springs from the non-nivomats springs though Link to comment Share on other sites More sharing options...
BEJinFBK Posted June 20, 2011 Report Share Posted June 20, 2011 If they ARE Nivo's, you can get'em for a lot less these days. Shop around - even IPD has pretty good prices on'em. I paid something like 225 when DW was still happy. For anyone interested, here's some info on Nivomats: nivomat.pdf Link to comment Share on other sites More sharing options...
CA855R Posted June 22, 2011 Report Share Posted June 22, 2011 Some of the wagons have the self leveling Nivomats. The shocks actually do level the ride by "pumping up" as you drive. If someone was cheap and replaced the nivomats (super expensive..like $400 each) with standard shocks, the car would sag as the springs are weaker due to some of the load being taken by the nivomats. Not sure how to tell the nivomat springs from the non-nivomats springs though Thinking more about this...I've seen cars with blown nivomat shocks sit just like that....if that's the case (or he swapped in standard shocks)..your best bet is to get a set of aftermarket springs with regular shocks as the price of new nivomats is high... x2 on this thought. I replaced my Nivos with stock shocks and Bils Touring on my rear 855R and the height looks about right even when loaded. The ride is also about the same as before. I pretty satisfied with this combo... Link to comment Share on other sites More sharing options...
rmorse Posted June 22, 2011 Report Share Posted June 22, 2011 Omg, is that a yellow t-5r wagon? Link to comment Share on other sites More sharing options...
Ozark Lee Posted June 22, 2011 Report Share Posted June 22, 2011 From the pictures that car is just plain shot and you need to get rid of it. I can be there with cash within an hour to drag it off to the junk yard for you. ...Lee Link to comment Share on other sites More sharing options...
boosted_brick Posted June 22, 2011 Author Report Share Posted June 22, 2011 Omg, is that a yellow t-5r wagon? sure is. you can come over and touch it if you want. Link to comment Share on other sites More sharing options...
rmorse Posted June 22, 2011 Report Share Posted June 22, 2011 sure is. you can come over and touch it if you want. Do want. Asl? (the wagon, not you) Link to comment Share on other sites More sharing options...
