SIAMBLUE Posted June 19, 2011 Report Share Posted June 19, 2011 HI Guys, i have just bought an HKS boost controller in the instructions it states you only need 2 wires to be spliced into, 1, the RPM signal and 2, the throttle input signal, does anyone here that have fitted a controller know what wires i have to splice into on my car? or maybe someone knows what wires they are? regards Gary Link to comment Share on other sites More sharing options...
lookforjoe Posted June 20, 2011 Report Share Posted June 20, 2011 HI Guys, i have just bought an HKS boost controller in the instructions it states you only need 2 wires to be spliced into, 1, the RPM signal and 2, the throttle input signal, does anyone here that have fitted a controller know what wires i have to splice into on my car? or maybe someone knows what wires they are? regards Gary This is my wiring for my Apexi AVC-R. pin terminals are numbered in the left side connector boxes (RPM) - TPS - you tap into the wire @ the TPS socket & run the wire into the cabin through the accessory conduit located behind & under the main fuse box. Link to comment Share on other sites More sharing options...
