boxpin Posted July 1, 2011 Report Share Posted July 1, 2011 The manual swap is done but I have the Check Engine light on and a blinking up shift light. What can I do about these? Link to comment Share on other sites More sharing options...
sconeman Posted July 1, 2011 Report Share Posted July 1, 2011 The manual swap is done but I have the Check Engine light on and a blinking up shift light. What can I do about these? did you pull out the TCU? never seen that after a manual swap personally Link to comment Share on other sites More sharing options...
(n)A-GAME Posted July 1, 2011 Report Share Posted July 1, 2011 Unless you're using a manual ECU you will get the blinking up arrow. As for CEL did you pull the codes? Maybe you knocked something loose or forgot to connect something. Link to comment Share on other sites More sharing options...
boxpin Posted July 1, 2011 Author Report Share Posted July 1, 2011 I will pull the codes when I get home today. Just fired it up last night and drove to work this morning. I did not pull the TCU. So is the blinking up shift arrow considered a present? Do I just remove that bulb? Link to comment Share on other sites More sharing options...
sconeman Posted July 1, 2011 Report Share Posted July 1, 2011 I will pull the codes when I get home today. Just fired it up last night and drove to work this morning. I did not pull the TCU. So is the blinking up shift arrow considered a present? Do I just remove that bulb? just pull the TCU out you don't need that anymore. You shouldn't get any cels when it's gone Link to comment Share on other sites More sharing options...
prasamin Posted July 1, 2011 Report Share Posted July 1, 2011 you can pull the TCU out, but the up arrow is there to stay unless you get a manual tune on your ECU. as for the CEL, did you do all the wiring for the reverse sensor/lights, and the gear position sensor thing, etc? there are some pins you have to jumper on trans harness to do all of these things.... Link to comment Share on other sites More sharing options...
boxpin Posted July 1, 2011 Author Report Share Posted July 1, 2011 I jumped the greens to start it but have not connected the reverse switch(blues). For the speed sensor it was just a plug-in. Link to comment Share on other sites More sharing options...
sconeman Posted July 1, 2011 Report Share Posted July 1, 2011 you can pull the TCU out, but the up arrow is there to stay unless you get a manual tune on your ECU.. oh hmm I guess the bulb is burnt out on my 850 then. Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted July 1, 2011 Report Share Posted July 1, 2011 WELCOME TO THE 5SP GROUP!!! The arrow go away after you pull the tranny ECU, you will got a CEL with two or few more codes: ONE for missing tranny ECU and TWO +all the cylinder misfire when the ECU cut off the gas! As stated above you need a manual ECU or talk with Lucky (ARD) Link to comment Share on other sites More sharing options...
need11@47 Posted July 1, 2011 Report Share Posted July 1, 2011 As stated above you need a manual ECU or talk with Lucky (ARD) I don't think Lucky is with IPD any longer. I'd suggest you call Scott Hart next week. Link to comment Share on other sites More sharing options...
Zappo Posted July 1, 2011 Report Share Posted July 1, 2011 I don't think Lucky is with IPD any longer. I'd suggest you call Scott Hart next week. Lucky, ARD. He never said IPD. :) Link to comment Share on other sites More sharing options...
Matt_ Posted July 1, 2011 Report Share Posted July 1, 2011 you can pull the TCU out, but the up arrow is there to stay unless you get a manual tune on your ECU. My up arrow was on for about a month before I did the swap, and never came back on after. WELCOME TO THE 5SP GROUP!!! The arrow go away after you pull the tranny ECU, you will got a CEL with two or few more codes: ONE for missing tranny ECU and TWO +all the cylinder misfire when the ECU cut off the gas! As stated above you need a manual ECU or talk with Lucky (ARD) +1 to everything Tizio stated. Only CEL I kept getting was related to the car not finding the TCU. I'd clear it and it would come back on with in 100 miles or so. I don't think Lucky is with IPD any longer. I'd suggest you call Scott Hart next week. Lucky is now doing tuning with his new company, ARD. http://ardideas.com/volvo.html Link to comment Share on other sites More sharing options...
boxpin Posted July 2, 2011 Author Report Share Posted July 2, 2011 I removed the TCU and the Check Engine and Up-shift light both turned off. Thanks guys. Link to comment Share on other sites More sharing options...
prasamin Posted July 2, 2011 Report Share Posted July 2, 2011 oh hmm I guess the bulb is burnt out on my 850 then. actually, you might be right....the up arrow may go away when you pull the TCU, but a CEL will be thrown for missing TCU and some other transmission stuff....it's been a long time, I don't remember exactly Link to comment Share on other sites More sharing options...
sconeman Posted July 2, 2011 Report Share Posted July 2, 2011 right now I have an auto ecu in with no TCU. no CEL and no shift light. Link to comment Share on other sites More sharing options...
