turbomike89 Posted July 7, 2011 Report Share Posted July 7, 2011 Hey guys! Has anyone had any luck doing an engine swap on a 03 s80 t6? I have a buddy thats offered to give me 400 bucks to just swap the motor. Has another engine with warranty. Is it worthwhile? Never worked on an s80 before. plenty of c70 s70 850's tho. How hard is it? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted July 7, 2011 Report Share Posted July 7, 2011 You'll want more than $400 for the job. The engine cannot be removed without taking the transmission out which means it needs to come out the bottom. Easiest way is with a lift and lowering the whole subframe down. Link to comment Share on other sites More sharing options...
rbodor3 Posted July 8, 2011 Report Share Posted July 8, 2011 you will need all electronics, sensors, ecu.... Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted July 8, 2011 Report Share Posted July 8, 2011 you will need all electronics, sensors, ecu.... Since the ECU is VIN coded the car, I'm not sure how that would work. Why would you need it anyways? Swapping another lockblock in is a bolt on affair. Link to comment Share on other sites More sharing options...
