Scania Posted July 12, 2011 Report Share Posted July 12, 2011 I think the T belt broke on start up in the 97 855R. Car didn't even really run, fired up & died off . . . . Wondering if it still bent all the valve's ? Link to comment Share on other sites More sharing options...
Matty Moo Posted July 12, 2011 Report Share Posted July 12, 2011 You think it broke? It either broke or did not break at all. Look and see if it's there. Link to comment Share on other sites More sharing options...
greekone Posted July 12, 2011 Report Share Posted July 12, 2011 Good chance it did, running a compression test will confirm wether or not your you'll be needing a new head. Link to comment Share on other sites More sharing options...
Keaton85 Posted July 12, 2011 Report Share Posted July 12, 2011 Taking ONE bolt out will show you what you need to know... broken=bent Link to comment Share on other sites More sharing options...
AverageVolvo Posted July 12, 2011 Report Share Posted July 12, 2011 1 12mm bolt. Remove and check FIRST DO NOT CRANK THE ENGINE OVER AGAIN until you inspect the belt. Broken likely means bent, but not 100% . Valve damage could be confirmed after putting a new belt on and compression checking it. Link to comment Share on other sites More sharing options...
Scania Posted July 30, 2011 Author Report Share Posted July 30, 2011 So finally got around to looking at the 855, Belt didn't break but appears to have jumped a Few teeth on both cam's & bent all the valve's as there's no real compression. What a son of a Bitch ! ! ! T-belt, tensioner's,water pump . . .ect where all done back at 115K car now has 155K on it. damned if you do, damned if you don't. Oh well . . . . .will have to tear the head off & see what's what. .............Dave Link to comment Share on other sites More sharing options...
Keaton85 Posted July 30, 2011 Report Share Posted July 30, 2011 As in did you do the compression check when the belt was off by a couple teeth? Or did you set the timing correct and then do a compression check? Link to comment Share on other sites More sharing options...
Scania Posted July 30, 2011 Author Report Share Posted July 30, 2011 Didn't have time to reset the timing. may try that next week, but odds are they're bent. Best place to buy valve's ? World Pac is who I was thinking of checking with. Link to comment Share on other sites More sharing options...
Keaton85 Posted July 30, 2011 Report Share Posted July 30, 2011 Ok, really, stop and think for a second. If you are off by a couple teeth you can have overlap which would cause low compression! Just chill and get the car sorted before jumping to conclusions! In the time you did a compression check you could have set the correct timing. Link to comment Share on other sites More sharing options...
Scania Posted July 30, 2011 Author Report Share Posted July 30, 2011 How many interference motors have you heard of that start up & don't bend valves. not Jumping to conclusions. . . .but more than likely they're bent. Will see Link to comment Share on other sites More sharing options...
Keaton85 Posted July 30, 2011 Report Share Posted July 30, 2011 Plenty, i just fix a 1.8T on a passat that was off by three teeth due to an accident. Ran like crap but once a new belt and everything was swapped its fine now. If you know these motor then you know they havw ZERO clearance! Like pantake every valve easy. Our 5cyl motors seem to have a bit more clearance so being off a few teetg MIGHT be ok. All depends on how much. Link to comment Share on other sites More sharing options...
bergmjs Posted July 30, 2011 Report Share Posted July 30, 2011 A few teeth might not be bent valves. You really should just set the correct timing then test it. Worthless to tear the head off when everything could be perfectly fine and you were just too lazy to check. Link to comment Share on other sites More sharing options...
erikv11 Posted July 30, 2011 Report Share Posted July 30, 2011 How many interference motors have you heard of that start up & don't bend valves. not Jumping to conclusions. . . .but more than likely they're bent. Will see At least one - yours. My NA jumped several teeth at startup, I mean a lot like 10 or more. I reset the timing and it fired right up. Compression was fine, ran fine. Then it blew a head gasket so I pulled the head and had it checked - machine shop confirmed the valves were sealing great, no bends. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted July 30, 2011 Report Share Posted July 30, 2011 How many interference motors have you heard of that start up & don't bend valves. not Jumping to conclusions. . . .but more than likely they're bent. Will see Sconeman's 855 last month. His jumped a couple teeth and was fine...a few degrees doesn't mean death Link to comment Share on other sites More sharing options...
sconeman Posted July 30, 2011 Report Share Posted July 30, 2011 correct. This is how far advanced my cams were, ~2 teeth. Nothing got damaged but there isn't much more room than that. Lucky told me that 3 teeth can be enough to bend the valves a little but there are no signs of damage. I have good high compression and rock solid 22inches of vacuum. Car ran like crap ( I drove it to work and back with the advanced gears before I knew) Link to comment Share on other sites More sharing options...
