vivalavolvo Posted July 14, 2011 Report Share Posted July 14, 2011 http://www.ntxtools.com/network-tool-warehouse/SOL-FIT409.html Are these safe to use in a permanent setup for adding an oil cooler? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted July 14, 2011 Report Share Posted July 14, 2011 As long as the monkey who crimps them knows what hes doing they should be fine. Any place thats crimps though should test them for you so cannot see a problem. Link to comment Share on other sites More sharing options...
vivalavolvo Posted July 14, 2011 Author Report Share Posted July 14, 2011 I will be that monkey lol, i was hoping some hose clamps would suffice. How much pressure runs through these? Link to comment Share on other sites More sharing options...
vivalavolvo Posted July 14, 2011 Author Report Share Posted July 14, 2011 I just brain farted and relized this is not the fitting i was looking for I need the female one. Coffee here i come! Link to comment Share on other sites More sharing options...
Che'_Moderator Posted July 14, 2011 Report Share Posted July 14, 2011 Make life easy on yourself and just use -8s Link to comment Share on other sites More sharing options...
vivalavolvo Posted July 14, 2011 Author Report Share Posted July 14, 2011 Yeah that was the plan, or cut the hard lines and flare them. Do you know what adapters i need to put the 8s on there? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted July 14, 2011 Report Share Posted July 14, 2011 Yeah that was the plan, or cut the hard lines and flare them. Do you know what adapters i need to put the 8s on there? No because I have no idea what oil cooler you have. Link to comment Share on other sites More sharing options...
vivalavolvo Posted July 14, 2011 Author Report Share Posted July 14, 2011 No because I have no idea what oil cooler you have. Sorry, i meant transmission side. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted July 14, 2011 Report Share Posted July 14, 2011 We building an oil cooler or transmission cooler? This thread is a fluster cuck. OEM is PG-16 thread. Most coolers are AN or NPT Link to comment Share on other sites More sharing options...
vivalavolvo Posted July 14, 2011 Author Report Share Posted July 14, 2011 Trans cooler. I'm not worried about what fittings are on the coolers, i just need to know what threads are on the trans so i can shop for adapters and get parts to match for a nice clean setup. Link to comment Share on other sites More sharing options...
vivalavolvo Posted July 14, 2011 Author Report Share Posted July 14, 2011 Oil cooler will be another project. Link to comment Share on other sites More sharing options...
the commissar! Posted July 14, 2011 Report Share Posted July 14, 2011 go to JY, get spare set of OEM transmission lines. Remove hose and replace with 2 hoses suitable for application of appropriate length with fittings on the "other/cut end" to match what your cooler has in the size appropriate for the hose... Rinse and repeat for oil cooler if you like unless your going to swap to the newer setup with the cooler on the oil pan. Link to comment Share on other sites More sharing options...
vivalavolvo Posted July 14, 2011 Author Report Share Posted July 14, 2011 go to JY, get spare set of OEM transmission lines. Remove hose and replace with 2 hoses suitable for application of appropriate length with fittings on the "other/cut end" to match what your cooler has in the size appropriate for the hose... Rinse and repeat for oil cooler if you like unless your going to swap to the newer setup with the cooler on the oil pan. That was going to be my fall back plan as i mentioned up a bit. I will cut the lines and put a flare on it, or if i can get my hands on it, one of those tools to put those bumps on it, the top it off with a couple hose clamps for safety. Link to comment Share on other sites More sharing options...
the commissar! Posted July 14, 2011 Report Share Posted July 14, 2011 That was going to be my fall back plan as i mentioned up a bit. I will cut the lines and put a flare on it, or if i can get my hands on it, one of those tools to put those bumps on it, the top it off with a couple hose clamps for safety. small flare and oetiker clamps ftw Link to comment Share on other sites More sharing options...
vivalavolvo Posted July 14, 2011 Author Report Share Posted July 14, 2011 small flare and oetiker clamps ftw This looks like some sort of hybrid clamp Link to comment Share on other sites More sharing options...
