InitialDriveGTR Posted July 21, 2011 Report Share Posted July 21, 2011 How the hell can I run it. The piece I had made when I did my FMIC isn't holding up to higher boost levels. How do most people deal with the IAC when you upgrade to 3" TB's? Link to comment Share on other sites More sharing options...
Zappo Posted July 21, 2011 Report Share Posted July 21, 2011 Show us what you made. I am running a 3" TB and my works. Link to comment Share on other sites More sharing options...
Oreo931 Posted July 21, 2011 Report Share Posted July 21, 2011 Old picture, but you get the idea: Link to comment Share on other sites More sharing options...
sconeman Posted July 21, 2011 Report Share Posted July 21, 2011 Old picture, but you get the idea: same kind of thing here: Link to comment Share on other sites More sharing options...
lookforjoe Posted July 21, 2011 Report Share Posted July 21, 2011 Old pic of mine - I put a straight fitting in the intake pipe & used the stock IAC pipe cut out of the original TB hose I since fitted a 90º port on the intake, and rotated the IAC, still uses the same hoses - I like to keep them as short as possible Link to comment Share on other sites More sharing options...
Brad850 Posted July 21, 2011 Report Share Posted July 21, 2011 Bought snabb's 3 inch hose and improvised a little. Link to comment Share on other sites More sharing options...
bergmjs Posted July 21, 2011 Report Share Posted July 21, 2011 Bought snabb's 3 inch hose and improvised a little. I did the same, except improvised a little differently. I angled the main inlet of the Snabb hose downward so the actual FMIC piping was as simple as possible, then got 6 inches of some 1" reinforced vinyl hose with a butt-connection adapter. So I extended the IAC arm that comes off the Snabb hose an additional 6 inches and was able to wrap it up to the IAC effectively. No picture right now Link to comment Share on other sites More sharing options...
Zappo Posted July 21, 2011 Report Share Posted July 21, 2011 Still waiting for the OP to post a picture, or at least describe what he did. :) Link to comment Share on other sites More sharing options...
lookforjoe Posted July 21, 2011 Report Share Posted July 21, 2011 Still waiting for the OP to post a picture, or at least describe what he did. Indeed! :lol: Link to comment Share on other sites More sharing options...
InitialDriveGTR Posted July 21, 2011 Author Report Share Posted July 21, 2011 yeah theone I had made was out of two silicone couplers using the original TB hose, and rotated the IAC I used a couple pieces of piping clamped together then wrapped with electrical tape. I hadn't accounted for the heat this summer when I originally made it which is causing the glue to melt and it's causing annoying leaks AS it sits with the new TB..Still having the same issues, but not as bad: Link to comment Share on other sites More sharing options...
Zappo Posted July 21, 2011 Report Share Posted July 21, 2011 So, that red silicone hose is coming apart on you? Link to comment Share on other sites More sharing options...
InitialDriveGTR Posted July 21, 2011 Author Report Share Posted July 21, 2011 So, that red silicone hose is coming apart on you? Thats not one piece os silicone... It's two then wrapped with a stuff load of electrical tape Link to comment Share on other sites More sharing options...
cgally Posted July 21, 2011 Report Share Posted July 21, 2011 I bought a vacuum nipple kit at Pep Boys. I used the stock IAC coupler and clamped the cut ends. It held 17lbs no prob. Use a reducing coupler to connect to TB. It was very easy. Link to comment Share on other sites More sharing options...
Zappo Posted July 21, 2011 Report Share Posted July 21, 2011 Get the part made in metal and the problem is solved. I had a 1" pipe added to my pipe going into the TB for the IAC. I believe Josh wasn't planning on using AC, so was probably going to bypass the IAC. I use the AC, so I had the pipe added in. Link to comment Share on other sites More sharing options...
InitialDriveGTR Posted July 21, 2011 Author Report Share Posted July 21, 2011 Get the part made in metal and the problem is solved. I had a 1" pipe added to my pipe going into the TB for the IAC. I believe Josh wasn't planning on using AC, so was probably going to bypass the IAC. I use the AC, so I had the pipe added in. Wait, when you say AC, you mean Air Conditioning? Link to comment Share on other sites More sharing options...
