deepsovlov Posted July 26, 2011 Report Share Posted July 26, 2011 I recently swapped a 6mm vacuum line (marked red) to a 4mm because the clamp is missing so the line keeps popping out. When i went for a test run i immediately noticed the car felt sluggish,no response, like there was very little to no boost even with my foot planted hard on the accelerator. My normal 0-60mph is around 6.5sec,but now it was 11-12sec. So does the vacuum line size really matter & makes that much of a difference? Please explain Link to comment Share on other sites More sharing options...
Che'_Moderator Posted July 26, 2011 Report Share Posted July 26, 2011 The short answer is yes, but that much slower is not due to size change. You either forgot to hook one up and have a massive leak or a line is collapsing. Just use a zipie and they will not pop off. Link to comment Share on other sites More sharing options...
deepsovlov Posted July 26, 2011 Author Report Share Posted July 26, 2011 Thanks. As soon as the engine cools abit im going to check out the entire engine bay again for anything lose. Also i will use a larger vacuum hose & see if theres any performance difference. Also theres been a few times when all of the caps on the vacuum tree completely popped off? Every other month i have to replace at least one thats missing and there on very tight. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted July 27, 2011 Report Share Posted July 27, 2011 Use safety wire or zip ties. Link to comment Share on other sites More sharing options...
