c_long20 Posted July 30, 2011 Report Share Posted July 30, 2011 I got the intake spacer from Snabb. It says no intake gaskets required, but I don't want to do this twice. I'm lazy like that. Do I need to go ahead and put a gasket on either side of the spacer. Link to comment Share on other sites More sharing options...
tchnprgrmr Posted July 30, 2011 Report Share Posted July 30, 2011 you don't need to, but there is no harm in doing so. Link to comment Share on other sites More sharing options...
AverageVolvo Posted July 30, 2011 Report Share Posted July 30, 2011 Don't need too. But if you did, you would want 2 gaskets. 1 on each side of the spacer Link to comment Share on other sites More sharing options...
gmsgltr Posted July 31, 2011 Report Share Posted July 31, 2011 i didnt use one... been running it for two weeks now... Link to comment Share on other sites More sharing options...
sconeman Posted July 31, 2011 Report Share Posted July 31, 2011 don't use extra gaskets unless you get some longer bolts. Polyethylene is self sealing, just torque it down to spec (~14 ft lbs) from the center out just like in the VADIS instructions. Do not over torque the bolts. Link to comment Share on other sites More sharing options...
c_long20 Posted July 31, 2011 Author Report Share Posted July 31, 2011 Thanks, I put it on last night without the gaskets and it seems to be doing just fine. Iat's are nice and low too! Link to comment Share on other sites More sharing options...
Mesoam Posted July 31, 2011 Report Share Posted July 31, 2011 "nice and low"? how about actual temps since 98's have that wonderful feature through OBD2 port Link to comment Share on other sites More sharing options...
tchnprgrmr Posted July 31, 2011 Report Share Posted July 31, 2011 you know that the OBD2 IAT isn't in the manifold, right? Anyway, i installed a gasket on each side of my spacer, used stock bolts. it has been holding up fine for several months without any problems. I took a few readings at idle after a quick WOT run. Block: Intake Manifold: Link to comment Share on other sites More sharing options...
gmsgltr Posted August 1, 2011 Report Share Posted August 1, 2011 ^^^ cool, good to see Link to comment Share on other sites More sharing options...
c_long20 Posted August 2, 2011 Author Report Share Posted August 2, 2011 They are running bw 129 and 134 depending on how I've been driving. They were like 160 or so, I only checked it like twice. Still holding good w/o gaskets. Link to comment Share on other sites More sharing options...
NEU Posted August 2, 2011 Report Share Posted August 2, 2011 Anyone got advice on the easiest way to install this on a ME7? Is is doable with out taking everything apart? Can I just undo the intake runner, remove the old gasket and slip in or do I need to remove the plumbing and remove the runner. Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted August 2, 2011 Report Share Posted August 2, 2011 On the ME7 you have less space to work than M4.4 so I might suggest to remove the plumbing. Link to comment Share on other sites More sharing options...
